ok not a powertool but work/camping/ garden emergency light
You can post and read reviews of all Power tools in here. Tools will be listed by manufacturer, Model number and / or description.please ensure that you put the correct power tool under the correct manufacturer. If the manufacturer is not yet listed then please post in the general part of the power tool review forum.
Has thanked: 734 times
Been thanked: 2333 times
ok following on from uhms battery lights
i bought one that he suggested'
a 20w led claims to run for 4 and charge in about 5hrs
in actual fact it was nearer 3hrs run and 5 hrs charge but very very bright
i have also bought another 20w at £9 cheaper i suspect its perhaps 30 or 40% less bright but the run time as we speak is into the fourth hour so well pleased
http://www.ebay.co.uk/itm/191605239397? ... EBIDX%3AIT
the chargers suggest the battery packs are a bit different
uhms one is 12.5 v charge this suggests 3x3.6v cells at 10.8v and a 15% overvolt to charge at 12.4
the other one is rated at 8.4v so 2x 3.6v at 7.2v + 17%
light just went out after 4 hours
now the way this would work is 6 cells in the first one 3 in parallel then 2x in series so 12v
the other will be 2 in parallel x3 in series
will post links and charging amounts and times tomorrow when i get time :lol:
origional thread here
led-work-light-t80394-15.html
Re: ok not a powertool but work/camping/ garden emergency li
will work out the power consumption figures later :lol:
Return to “Power Tool Reviews”
