Tiling dilemma
mika_98
Tiling dilemma
Post by mika_98 »
Hello all,
I seem to be in a dilemma with the tiler and tiling my bathroom. First of all, things to bear in mind are that the walls are slightly damp and I have gone for porcelain tiles. The walls have been treated with a damp proof course but I have been advised any previous damp may remain for a while.
With that in mind, I'm assuming the best method is to fit a board of some sort to tile onto. If that is correct, which method should I use - dot and dab with adhesive or studwork?
I'd rather go with the dot/dab as my bathroom is very small (1.8 x 1.5m). Batons plus boards, followed by tiles will take up what little space I already have. If I go down this route, which boards (apart from plaster/MR) can I fit using adhesive? I'd love to use something like Aquapanels but was advised they have to be fitted using batons. Are there any other alternatives?
However, if its best to go with batons+boards, which combination can I go with (again apart from plaster/MR) that will take up less space? Aquapanels I believe require a 38mm baton according to the manufacturer!
Also, I've never heard of this but the tiler wishes to add some kind of waterproof additive to the grout I prefer, which is one from the Mapei range. Anyone ever heard of such practice?
I would be very grateful of any advice as it's causing me some bother :oops:
Timllfixit
Has thanked: 146 times
Been thanked: 209 times
Re: Tiling dilemma
Post by Timllfixit »
Hi mika_98.
It seems these can be screwed directly to the wall. You will need the special washers though. Dunno what thickness you will need, but the tiler might know.
http://www.wetroomsupplies.co.uk/3-dukk ... ker-boards
wine~o
Has thanked: 1414 times
Been thanked: 4019 times
Re: Tiling dilemma
Post by wine~o »
:welcomeuhm:
I'd be making 100% sure that the damp is cured before tiling........
steviejoiner74
Has thanked: 747 times
Been thanked: 1616 times
Re: Tiling dilemma
Post by steviejoiner74 »
:withstupid: and remember read the terms of the guarantee on you damp treatment,usually you'll not be able to do anything to any treated walls for 6 months(even wallpapering!) or it'll invalidate the gaurentee.
Return to “Tiling Forum”
