- Ultimate Handyman Forum Index DIY Forum/Home improvement Carpentry/Joinery Forum Kitchen Fitting
- It is currently Sat Apr 05, 2025 6:58 am
Is a 25mm guide bush ok in my jig?
- Has thanked: 2 times
Post by mattbowman81 »
I've stupidly come to work away for the weekend, and left my trend universal base and 30mm collet at home. I need to finish the worktops by tomorrow, and no where has anything in stock to fit my makita router.
I have a 25mm guide bush, which will fit on my router. My thoughts are that as long as tho bush keeps to the correct edge of the jig, everything should cut and fit together fine.
Any thoughts?
Any thoughts?
mattbowman81
- Timllfixit
- Has thanked: 146 times
- Been thanked: 209 times
Re: Is a 25mm guide bush ok in my jig?
Post by Timllfixit »
You would have the problem of the bush being loose in the slot, so you would have to go steady and keep it over to one side or the other. Don't forget the cut will be 2.5mm out compared to usual.
- These users thanked the author Timllfixit for the post:
- mattbowman81
Timllfixit
Thanks for the quick reply. I thought it'd be a couple of mm out, but as long at they're all cut the same, it should be ok. I think I may have found a B&Q about 20 miles away that has a trend universal sub base in stock. Fingers crossed come 10am tomorrow morning!
mattbowman81
- big-all
- Pro Carpenter
- Has thanked: 740 times
- Been thanked: 2355 times
will the cutter fit through the bush center ??
thev radius will also be fractionally smaller
- These users thanked the author big-all for the post:
- mattbowman81
Yes, it's only a 12.5mm cutter, so will just go through with enough clearance. Hopefully, I'll manage to get hold of a sub base, and perform the cuts as per the norm.big-all wrote:will the cutter fit through the bush center ??
mattbowman81
- ayjay
- Has thanked: 458 times
- Been thanked: 1708 times
I'm fairly sure it won't work, you need a 30mm guide bush.
It definitely doesn't work with a 16mm guide bush.
ayjay
- Timllfixit
Shame you can't find a cardboard tube of the right size to pop over the bush you have..................
Timllfixit
- big-all
- Pro Carpenter
pollypipeTimllfixit wrote:Shame you can't find a cardboard tube of the right size to pop over the bush you have..................
- Job and Knock
- Old School Chippie
- Has thanked: 742 times
- Been thanked: 1573 times
Post by Job and Knock »
I'm with Ayjay in saying it won't work. The relationship between the jig, the cutter (incidentally 12.7mm or 1/2in and not 12.5mm which would leave a gap in the corner) and the guide bush is absolutely critical, especially as the mason's mitre joint includes a curve. I've had to work this out in the past in CADCAM and changing the size of any element by even 0.5mm can reult in a "gappy" joint - even using a cheap slightly undersize guide bush can introduce a noticeable gap in the finished joint
Job and Knock
