Multi fuel stove paint problem
Stoves and stove related questions
Trimmer44
Post by Trimmer44 »
Hi all, I've just finished installing our stove at home. I lit it and went to make a cuppa! Wen i went back into the lounge i i noticed the paint peeling on the stove and a smoke coming off the surface. Its a second hand hunter hawk and i was told it was painted last year, I'm dubious now and wondering it must have been painted in normal paint as my room was filling with this smoke! In Know the installation is fine and my co alarm is still showing 0ppm but the temp it shows is rising! Any ideas on wether this paint is rite or not??
Rorschach
Has thanked: 120 times
Been thanked: 1043 times
Re: Multi fuel stove paint problem
Post by Rorschach »
if peeling and smoking, clearly not!
Trimmer44
Post by Trimmer44 »
How would you fix this problem?
Has thanked: 48 times
Been thanked: 2604 times
Strip all the paint and re paint with the correct paint.
steviejoiner74
Has thanked: 747 times
Been thanked: 1616 times
Post by steviejoiner74 »
You get paint specifically for stoves and flues. It stinks a wee bit after the first fire has been lit but doesn't peel off!!
Return to “Stoves”
