Assorted projects.
- Retired
- Has thanked: 2022 times
- Been thanked: 588 times
Assorted projects.
I've just been looking through old files and have pulled out a few pictures of projects I've done over the years these just being a random sample. I was taught to us my head and hands and to this day this is what I still do. When many would throw away or scrap things I enjoy the challenge of restoration whether it be old machinery or even vintage radios and all in-between. I enjoy trying out new ideas especially those which have not been done before so hopefully I'll not bore you but how many other members tackle such an assortment of projects making; restoring and attempting something which has never been attempted before; as I say the pictures are just a small sample but every one of them has afforded me lots of interest.
Winding the huge 75kg transformer from scratch was about the most dangerous project I ever tackled; I'm no electrician but by doing this I installed 3 phase into our garage for under £120.
I bought a very rough Union Graduate wood turning lathe and fully restored and upgraded it to 1.5hp through a VFD; this lathe was in need of a number of new parts so rather than get my hand into my pocket I made the parts; the tail stock locking lever had been bodged so I turned a brand new shaft adding a correct locking cam then I made a new handle.
During my radio restoration years again something I knew nothing of so learnt from scratch I made lots of kit including my own power supply units (PSU). The one shown has two home wound transformers covering high and low DC voltages giving a choice of six outlets to cover DC voltages in both negative and positive; being able to wind own transformers is a very interesting task.
A little job I dreamt up one night in bed was to design and make the miniature coil winder; this allowed tiny coils to be added to the lead ends of components such as capacitors and resistors; I had this one published and I know quite a few have been made in fact I've made over a dozen and given them away as prezzies; I used to need three hands for changing a component; one to hold the soldering iron; one to hold the solder and one to hold the component being soldered; adding tiny coils meant I could snip out the original component leaving a 1/4" long tail; this in turn would be scraped clean then it was incredibly simply to slip on the new component leaving both hands free for the soldering; a couple of other problems were also solved at the same time; by leaving the 1/4" long tails the position of the connections was never lost also as the soldering was much quicker it didn't disturb other components at the same connection on such as a valve base. A simple winding device but ever so useful.
I like to do woodturning and woodturning kit is always expensive especially top kit like Sorby; why pay the price when I can make my own such as the "chatter tool" I made two of these chatter tools and gave one to my chum David another wood turner. I've added a picture of the sample chatter work I ever did; not bad at all for a first attempt and done using the tool I made which was made from odds and ends costing nothing. What's chatter work? Please see the video.
Bron very generously bought me a Clarke lathe as a Christmas prezzie; it didn't last two minutes before I destroyed the motor and circuit board both expiring in a cloud of smoke; I'm used to lathes that will take a very heavy cut; I thought I was being gentle using the Clarke but it didn't like having to work. I bought a brand new industrial servo motor and dumped both the original motor and circuit board; I clamped the servo motor onto the Clarke head stock then used the Clarke to make a counter-shaft which I installed then added the servo motor permanently; now the Clarke would take a decent cut without going up in smoke.
I fully restored a vintage AVO Wave Winder and needed 45 gears for it; the winder came without a single gear; I came up with a new way of indexing and made the 45 gears on a lathe receiving a top award for this in 2009; this was related to vintage radio restoration and it was a big project.
Two machines I made from odds and ends costing very little indeed are my 4" belt sander and 2" belt grinder. The belt sander has it's belt running downhill whereas the belt grinder has its belt running uphill; the belt grinder is for grinding tool tips and I also had a leather honing belt specially made for this in Dallas Texas; I could not get a belt made here in the UK in fact I couldn't even get a strip of suitable leather but I'm persistent once I start one of my projects and will see it through however long it takes.
I've also fully restored lots of heavy machines over the years including lathes; industrial airless sprayer (DeVilbiss) and even an Hydrovane compressor. In latter years I've recorded the work both in text and in images; it's interesting for me to look back at the endless work I've carried out.
Kind regards, Col.
Kind regards, Col.
- These users thanked the author Retired for the post:
- ultimatehandyman
