Push open/close cabinet fittings
ahll
Has thanked: 87 times
Been thanked: 3 times
Post by ahll »
I am thinking of doing away with the cupboard handles and fitting those that you push the door to open and close.
Does anyone have recommendation as to good fittings to use ?
Have people who have done this found it to be a good move ?
London mike 61
Has thanked: 285 times
Been thanked: 403 times
Re: Push open/close cabinet fittings
Post by London mike 61 »
I've fitted then on our utility room cupboards and they work pretty well, we got ours from ikea where we got the cupboards from but you can get them elsewhere.
These users thanked the author London mike 61 for the post:
ahll
ayjay
Has thanked: 458 times
Been thanked: 1708 times
Post by ayjay »
If you do fit them, make sure to put the final fixing pins in once they're working correctly.
There's a few more styles around nowadays, but I'm referring to this very commonly available type shown below.
The small round hole in the flange at the side is where the pin goes.
These users thanked the author ayjay for the post (total 2):
multimanahll
Rating: 14.29%
aeromech3
Has thanked: 177 times
Been thanked: 665 times
Post by aeromech3 »
I would say from my experience avoid the ones with a white plastic hook striker, they often break across the tip.
These users thanked the author aeromech3 for the post (total 2):
multimanahll
Rating: 14.29%
Bob225
Has thanked: 106 times
Been thanked: 882 times
Post by Bob225 »
I have fitted a few of the buffer type ones not had a issue with any of them touch wood iirc they maybe Hafele
https://www.hafele.co.uk/en/product/pus ... 7&PDP=true
https://www.hafele.co.uk/en/products/ki ... oduct_type
These users thanked the author Bob225 for the post (total 2):
multimanahll
Rating: 14.29%
multiman
Has thanked: 689 times
Been thanked: 28 times
Post by multiman »
Just ensure you get alignment correct as well.
These users thanked the author multiman for the post:
ahll
keithski122
Has thanked: 4 times
Been thanked: 26 times
Post by keithski122 »
Also because the doors need to be pushed first before opening that the closed position is not fully against the stop so the doors may not lay flat.
These users thanked the author keithski122 for the post (total 2):
multimanahll
Rating: 14.29%
Return to “Kitchen Fitting”
