Page 1 of 2
laptop running hot (CPU?)
Posted: Sun Jan 28, 2018 7:06 pm
by wine~o
Basically as per title. Fan is clear of dust and has been blasted with canned air. CPU runs at mid to high 60's C under very low load*, fan on full speed and can be heard running... even when closed (the forum pages) the fan at full speed and CPU running hot ... Intermittent though. some days fine and then other days just seems to want to run hot ?
Ideas???
* just a couple of forum pages open
Re: laptop running hot (CPU?)
Posted: Sun Jan 28, 2018 7:58 pm
by boxedin
Hi Wineo
When you say low load what programmes are loading at start up check in windows 7 its system configuration/ startup and services and you can disable from there to get the full picture
What programmes are automatically checking for updates constantly eg Chrome every 15min adobe if you turn them off what if anything happens
What AV program are you running have you tried disabling my problem was mainly AVG
Does it run hot on start up ? what is the rpm of the fan running at (download speedfan to check)
Posted: Sun Jan 28, 2018 8:12 pm
by boxedin
speccy is good for hardware overview with temperatures download the free version of course
https://www.ccleaner.com/speccy
Posted: Sun Jan 28, 2018 8:58 pm
by DIY_Johnny
i would check to see what processes are running in the background, do a malware and antivirus check.
Another possibility could be that the CPU heatsink has come loose. They can do over time . Happened to mine!
Posted: Sun Jan 28, 2018 9:06 pm
by kellys_eye
Thermal compound between heat sink and processor can also 'dry out' and require replacement.
Posted: Sun Jan 28, 2018 10:00 pm
by DIY_Johnny
I would add that fans which come with PC's are pretty bog standard. You get buy a much better one that run near silent.
I have a liquid cooler external fan set up, ....but I'm a nerd.
It keeps the CPU at 35deg even at overclocking and running benchmarks. Before I changed it, the heatsink came loose and temps ran to 90 deg and it would just shut down.
Posted: Mon Jan 29, 2018 1:34 pm
by BillyGoat
DIY_Johnny wrote:I would add that fans which come with PC's are pretty bog standard. You get buy a much better one that run near silent.
Bit awkward for carrying around a laptop after doing that mod to it.... :mrgreen:
kellys_eye wrote:Thermal compound between heat sink and processor can also 'dry out' and require replacement.
:withstupid:
Posted: Mon Jan 29, 2018 1:44 pm
by Dave54
Yes, it'd happened to this desktop machine after about 18 months. Checked the temp and it was still up after dusting out.
Posted: Mon Jan 29, 2018 5:03 pm
by wine~o
boxedin wrote:speccy is good for hardware overview with temperatures download the free version of course
already had speccy installed hence knowing the CPU was running too hot.
Looks like I will have to remake the heatsink. Bugger of a job on the laptop though.
:withstupid:
Lappy got worse... when switched on this morning went up to 70 degrees just running speccy
Currently using the old laptop that you saved for me Billy Goat. :salute:
Posted: Mon Jan 29, 2018 7:30 pm
by boxedin
Hello wine~o
Is it running windows 10? have you upgraded to windows 10 if so it might possibly be another potential cause to rule out before disassembling
https://fossbytes.com/windows-10-cpu-te ... eat-issue/
Posted: Mon Jan 29, 2018 7:35 pm
by DIY_Johnny
Just a thought, has the fan connector come loose by any chance?
Posted: Mon Jan 29, 2018 7:42 pm
by wine~o
DIY_Johnny wrote:Just a thought, has the fan connector come loose by any chance?
:dunno: I'll take it apart and have a look. Oh and if it is a pcb fault what oven temperature and for how long ?????? :shock: :?
Posted: Mon Jan 29, 2018 8:00 pm
by DIY_Johnny
shove the whole lot it, what possible harm can it do :mrgreen:
Posted: Mon Jan 29, 2018 8:24 pm
by boxedin
If you put the whole lot in as solder melts at 188c (gas mark 5), then the plastic would melt before the solder and it would come out like a plastic blob with some bits of metal in wouldn't it ?
https://www.ifixit.com/Guide/Temporaril ... +oven/2240
Posted: Mon Jan 29, 2018 9:43 pm
by DIY_Johnny
boxedin wrote:If you put the whole lot in as solder melts at 188c (gas mark 5), then the plastic would melt before the solder and it would come out like a plastic blob with some bits of metal in wouldn't it ?
Yeah i think he knows I was joking, ...... or I hope so !
