What to use to fill holes drilled into tiles
lambertbeechcroft
Post by lambertbeechcroft »
I've had a workman come and do some tiling for me in the bathroom, he boxed in the pipework and tiled over it, looks nice, however he also drilled out a couple of circles through both the tiles and the boxing, so that we could get to the pipes to isolate the radiator if we needed to. He said that he would get a couple of "Beazles" (not sure if this is the right term), that would fit into the holes, but that was about 3 years ago. I'm not sure where to get the said beazles from, and I'm getting a bit fed up of waiting, anybody got any advice?
Many thanks
:roll:
Has thanked: 1012 times
Been thanked: 918 times
Post by ultimatehandyman »
Hi, and welcome to the forum.
What size are the holes roughly?
Mudster
Tiling Expert
Been thanked: 1 time
Post by Mudster »
http://www.screwfix.com/app/sfd/cat/pro ... 7&id=19706
Pipe collars, available at B&Q and other DIY Sheds, also available from plumbers merchants.
honeymonster
Post by honeymonster »
I think the workman that fit the tiles means blanking plugs-
http://shop.comdir.co.uk/Products.aspx? ... Template=C
BobProperty
plumbing and property
Post by BobProperty »
I think the word you were refering to is "bezel", which is a surround or mounting to hold another item or component.
Treat everyone like they are a rich distant relative, in whose will you'd like to be remembered.
Return to “Tiling Forum”
