Wallpaper Removal gone Bad
Diy disaster stories in this forum please, Tradesmen disaster stories are also welcome in here!
tommysmith
Post by tommysmith »
Evening all,
Started removing some lovely pink wallpaper to find that most of the underlying plaster came with it. The wall used to be external, but it not internal following an extension. As you can you, has exposed brickwork. Picture attached. Any suggestions much appreciated!
Many thanks,
Tom
Ktuludays
Has thanked: 250 times
Been thanked: 212 times
Re: Wallpaper Removal gone Bad
Post by Ktuludays »
Reskim that part.
wine~o
Has thanked: 1415 times
Been thanked: 4030 times
Post by wine~o »
Ktuludays wrote:Reskim that part.
But make sure the surrounding plaster is sound. Knock with your knuckles, solid is good, hollow sound then it wants coming off.
Ktuludays
Post by Ktuludays »
Did you use a steamer, too long in one place and you can pop the plaster off the wall
Return to “DIY Disasters”
