Two different speed ratings on same axle - is it an MOT fail?
- Has thanked: 159 times
- Been thanked: 17 times
Hi all
Just been told that it is, but wasn't aware and I'm sure it has passed like that before? Unless of course it was part of the recent changes?
I have a T rating on one rear, and an H on the other. The car's original spec is T so I've been told, so presumable the H is no problem per se as it is a higher rating. In fact, it can't be a problem as the two fronts are both H and there's no issue with those.
So does the speed rating have to be the same pairing per axle?
Cheers
Cheers
- wine~o
- Has thanked: 1414 times
- Been thanked: 4017 times
So long as the speed rating meets or exceeds the manufacturers spec you are fine. It's not like you are mixing cross-ply and radial tyres on the same axle...
(some people may be too young to understand that sentence,)
- Has thanked: 1300 times
- Been thanked: 1175 times
As w~o says.
Have a look at the manual here.
https://www.mot-testing.service.gov.uk/ ... index.html
Nothing as far as I can see about mixing tyre speed ratings.
- Has thanked: 99 times
- Been thanked: 875 times
Pmsl - if there both the same size, Are in good condition and have legal tread no issue - Do you really thing a tester has the time to go around every tire and note down the spec, and to know exactly the 10's of 1000's of combinations multiplied by the 1000's of manufactures and how every one treats there car, i think not
imho someone is trying to up-sale you some tires
I will have a look see at the mot handbook
Edit. As i thought load ratings are only applicable to class 5 and 7 (basically LGV and mini busses over 14 seats) some light reading https://www.mot-testing.service.gov.uk/ ... tion_5.2.3 (section 5.2.3 Tyres)
- Has thanked: 814 times
- Been thanked: 3508 times
Did I read somewhere about the spare having to be rated the same as what is on in case you have to change a wheel?
Ah found it ..........................
a.A tyre:
i.load capacity or speed rating not in accordance with the minimum requirements
From another part of the type approval book "The speed capability of all tyres fitted shall be not less than the maximum design speed of the vehicle" eg. what the manufacture specifies
a.A tyre:
In the case of spacesavers there rated to 50mph (usually have a big sticker on the rim rule of thumb is 50 mph for 50 miles (or less)dewaltdisney wrote: ↑Tue Jul 23, 2019 4:18 pm Did I read somewhere about the spare having to be rated the same as what is on in case you have to change a wheel?
It's as I thought then. Interestingly though, he isn't trying to sell a tyre and recommended getting one from elsewhere as it would be cheaper. So I don't think it is an up-sell. He also said we can swap it for the spare if it is appropriate.
What I should add is that the tyre in question is a winter tyre. But forgetting performance, economy, etc etc. even that shouldn't make a difference RE the MOT should it?
Thanks for all the replies
