What cable do I need?
Telecommunications, Broadband and networking questions in this forum please
Argyll
Has thanked: 1191 times
Been thanked: 583 times
Post by Argyll »
I want to run a cable from my router in my living room to my bedroom upstairs. This is to connect my Amazon Firebox via ethernet. The best method is to run it externally. What cable do I need? Is it CAT 6? I have quite a long run of this but it's white which I presume is only for internal use?
Bob225
Has thanked: 106 times
Been thanked: 882 times
Post by Bob225 »
Cat5e cable will do the trick, colour has nothing todo with its use - you need external grade cable eg. https://www.ebay.co.uk/itm/External-CAT ... SwNp1bw3gj
If you dont want to run a cable powerline adapters will be perfect for this situation
eg. https://www.amazon.co.uk/TL-PA4010PKIT- ... 01G5Q9E0O/
I will update sortly with some links
These users thanked the author Bob225 for the post:
Argyll (Wed Aug 07, 2019 8:09 am)
Argyll
Post by Argyll »
I'd much prefer the cable rather than the adapters.
Bob225
Post by Bob225 »
all you need is 2 face plates, 2 back boxes and the external cable a punchdown tool will help no end
If you dont want a full size faceplate you can get a surface mount one unless your going to just terminate into a plug
Return to “communications and broadband”
