Punctured a pipe, anyone knows what it is?
Diy disaster stories in this forum please, Tradesmen disaster stories are also welcome in here!
Dima_1
Post by Dima_1 »
Hey all,
Have been prepping floor for new carpet and punctured an unknown pipe through the side.
Looks metallic inside, does anyone know what is it?
We have just moved in so have no good idea
Rorschach
Has thanked: 120 times
Been thanked: 1043 times
Post by Rorschach »
What came out of it when you punctured it?
Dima_1
Post by Dima_1 »
Nothing happened, It seem to have think metallic walls and my screw made a hole in the wall..
Bob225
Has thanked: 106 times
Been thanked: 882 times
Post by Bob225 »
how thick is it ? it may be old Lead/mineral cable if so its 60+ years old as it doesnt look a uniform size/shape
Dima_1
Post by Dima_1 »
Bob225 wrote: Tue Aug 13, 2019 9:51 am how thick is it ? it may be old mineral cable as it doesnt look a uniform size/shape
It about 3 cm in diameter, it is uneven and it bends at almost 90 degrees and turns into one of the bedrooms
Bob225
Post by Bob225 »
Victorian/edwardian house ? it may be old lead gas pipe used for gas mantles
Dima_1
Post by Dima_1 »
Bob225 wrote: Tue Aug 13, 2019 10:05 ammantles
Thanks for the reply, the house is from 1935, and the pipe feels very heavy (as in lead) indeed.
Its on the first floor so must by disused by now?
Rorschach
Post by Rorschach »
If it is lead you should be able to shave a bit of easily with a sharp knife leaving a clean shiny surface underneath.
Has thanked: 48 times
Been thanked: 2604 times
I can't help but wonder, if it is lead, why is it across the joists? isn't that idea a bit too modern? I have seen gas lights and the pipes were in the walls, as in they were installed when being built, doesnt look quite the same for those pipes, and are they not a bit too clean?
Has thanked: 831 times
Been thanked: 3627 times
I wondered if they are passivated mild steel pipes. The Gas Board had a cheap installation package for central heating in the 60's that used PMS pipe instead of copper. It was a disaster and it got dumped in due course. I wonder if this is redundant central heating pipe that was left there?
OnlineOnline
Bob225
Post by Bob225 »
1935 is a bit late for matles, just old lead plumbing ? old bathroom ?
Argyll
Has thanked: 1191 times
Been thanked: 583 times
Post by Argyll »
It's an old water pipe. The old gas pipes were cast iron. Strip it out and take it to the scrappys :thumbright:
toolbox
Has thanked: 131 times
Been thanked: 217 times
Post by toolbox »
There were old lead of "compo" pipes used for gas but not to be expected in 1930 I would have thought except for meter connections.
Wonder if it is from the early 70's during the Rhodesia crises copper was hard to get and lots of (largely unsuccessful) alternatives were marketed and used for heating installations. Being a pair flow and return springs to mind.
Maybe microbore.
OnlineOnline
Bob225
Post by Bob225 »
..... Or hot and not, old bathroom turned into a bedroom ?
Return to “DIY Disasters”
