Questionable Solution?
Posted: Tue Aug 27, 2019 3:42 pm
Problem: previous guttering blocked a fire window being opened because the fascia board was too thick.
Roofer solution: rather than take the old board off and fit a flat board, the guttering was cut away near the window and a piece of flashing was shaped into a gutter. The old fall pipe from the main building was repositioned, but left leaning on top of the annexe roof to discharge water.
Unavoidable solution or a cheap bodge??
Roofer has agreed to extend fall pipe into gutter, but still did the homeowner need to ask?
