Intergas eco rf36 hive thermostat wiring
Posted: Tue Nov 19, 2019 11:05 pm
by Frankieholmes
Can anyone help with a wiring diagram to connect a hive active thermostat to an Intergas eco rf36 boiler?
Posted: Wed Nov 20, 2019 4:27 pm
by Razor
Posted: Sun Jan 01, 2023 1:03 pm
by Bertiebasset
Hi, I can understand the wiring diagram, but 1&3 goes to low voltage side. The manual says no 240v to go to low voltage side ?
Posted: Mon Jan 02, 2023 11:11 am
by Razor
Terminals 1&3 on a Hive don't have any voltage they are just a switch, (relay).
It just takes the low voltage switch line from the boiler then send it back to the boiler when heat is called for.
If you aren't sure then why not get boiler serviced and the thermostat fitted at the same time?
Lastly the Hive is one of the least efficient thermostats you can fit to an Intergas. Anything that's Opentherm would be a much much better choice!
