Hi all, just joined and I have several questions regarding bending clear plastic sheet for the purposes of making several display cases, I have been researching it a bit on google and watched several U tube vids, on one "google hit" they state hot wire bending has problems over 24"- 36" lengths and above,(like "waving" or "bowing") going to make a bending machine similar to the ones shown but I would like to be able to bend up to 1.5 metre lengths, all the vids I saw were short lengths, I indent to make clamps to hold the material to the base and the moving part of the bender along with other angles etc, Also i don't know the difference between Perspex, Acrylic and Polycarbonate, so my questions are, what's the best material to use?, what Nichrome wire gauge will I need for 1500mm bend length?, and can anyone recommend a decent variable transformer/power source that's not going to require me to re-mortgage?
Going to try and make a real professional job of this bender and i'm sure a can make it a bit better than some of the ones I've seen on U tube, what I want to do is be able to bend "U" shapes for the display cases and just cut panels for each end or in one case join three together for an extremely long model truck and trailers model I made, ( Aussie road train) the other two large ones are for 1/200th scale ship models at just over 1200mm long each (battleship Yamato and carrier Shinano), thanks in advance for any ideas you guys can supply, regard's, Ian
