Paint ?
Tryanything
Been thanked: 4 times
Paint ?
Post by Tryanything »
Just finished rebuilding my cylinder head and want to paint it to make it
look nice as l dont like the rust look (cast iron head)
My question is as cylinder heads get quite hot im thinking there must be
a special paint, has anybody any idea ?
Bludall
Forum Chatterbox
Has thanked: 39 times
Been thanked: 7 times
Post by Bludall »
Hi Tryanything,
Would this be any use? The engine enamel.
Paint
Or this make?
Hycote
Failure means you just didn't get it right yet!
Louise
Tryanything
Thanks Louise looks like thats the jobby :thumbright:
Maybe the red me thinks
Hitch
Has thanked: 77 times
Been thanked: 335 times
Post by Hitch »
Have a look on the frosts website.
Perhaps something like a heat proof enamel, like caliper/drum pait if you want a fancy colour.
http://www.frost.co.uk/productList.asp? ... t=Painting
Tryanything
Cheers Hitch :thumbright:
peter c
Has thanked: 6 times
Been thanked: 16 times
Post by peter c »
TA I have used Simoniz Sperex in the past (in my days of GT Cortina's) with excellent results. As far as I know it withstands the highest temperature.
Peter C
The end justifies the means
Raf
Has thanked: 1 time
Post by Raf »
all high temp paints will do the trick or you could powder coat?
if the block justifies it you could polish it with some autosol? lots of hard work and elbow grease required but you can get a near mirror finish on it.
Tryanything
OooW it dont arf look pretty
And like the silly fool that l am (yes) l had to go further so l polished the
camshaft cover, what a slog that was, looks nice though
Yes Raf the block would look nice polished but no thanks
Bludall
Forum Chatterbox
Post by Bludall »
What colour did you end up painting it then?
Louise
Tryanything
Nice bright red
And this is after
And this is after
cylinder head 004.jpg (45.64 KiB) Viewed 2271 times
In case you cant tell this is before
cylinder head 003.jpg (55.36 KiB) Viewed 2271 times
Bludall
Forum Chatterbox
Post by Bludall »
I'm not a petrol head but that is lovvvely!! :thumbright: Good job!
What kind of vehicle is it from?
Louise
Hitch
Post by Hitch »
Ford 1.8 diesel isnt it?
stevemastic
Post by stevemastic »
not even a turbo?
Knock Knock Knock........ Stevies home!!!!
nil illegitimus carborundum
Tryanything
Its from my escort van that the cambelt went on last year
Looks good now but will look poop when it goes back iunder the bonnet :lol:
Bludall
Forum Chatterbox
Post by Bludall »
Are you going to steam clean what's left under the bonnet, so it all looks pristine?
Louise
