110V Transformer and 110V Power Tools?
Jaeger_S2k
Pro Handyman
Has thanked: 21 times
Been thanked: 27 times
Post by Jaeger_S2k »
If a power tool was bought in the states, 110volt and you have a 110v Site Transformer would it be fine to plug the states side power tool with a 110V plug and run it?
What effect would the difference in frequency have? USA 60Hz UK 50Hz
Jaeger.
Has thanked: 740 times
Been thanked: 2355 times
depends a lot on the tools
wont affect some but others may run hot or under powerd
the simple answer is you wont know till you try!!!!!!
OnlineOnline
Scrit
Pro Cabinetmaker
Re: 110V Transformer and 110V Power Tools?
Post by Scrit »
I've been using several Porter-Cable routers and a sander this way for about 5 years now - to date no problems apart from the single-speed stuff running a bit slower and slightly warmer, so the life may not be so good in the long term
Scrit
Measure twice, cut once - except fingers!
Jaeger_S2k
Pro Handyman
Thanks for that, I thought they'd be 'OK''ish.
Jaeger.
Return to “Tool Talk”
