what would you do here?
DIY_Johnny
Mr. Grumpy
Has thanked: 25 times
Been thanked: 109 times
Post by DIY_Johnny »
Hi all, can I ask what you guys would do here for preparing the walls for tiling for a bathroom
Pict 2 is where I took an old bath out
Pict 4 is a sample wall where I took the tiles down
Pict 3 is where the new shower will be going in. I need to oput in a stud wall here to hide the shower controls and feeds, so was going to use aquapanel for this part and tank
I was think that some of the walls could be just patched up like in pict 2 and 3.
There seems to be so many different types of plaster you can buy. Its a bit confusing. Should I just get an undercoat plaster and patch up the walls, wait til dry, tank with BAL WP1 or the dunlop one, (for shower area)then use BAL tile flexible tile adhesive
Q1) What type of plaster should I be looking for? Will Thistle Undercoat plaster do, do I need a finishing plaster also?
Q) One what is painted (not shown) will tile adhesive stick to that? The paint is fairly firm
Q3) do I need to prime the wall before and after I plaster
I may just end up with Dot and Dab plaster board of I make a mess out of it as I want to use big tiles hence I assume the wall has to be fairly straight :wink:
Thanks in advance
bathroom 3 (Small).jpg (28.1 KiB) Viewed 3754 times
bathroom 2 (Small).jpg (48.37 KiB) Viewed 3754 times
bathroom 4 (Small).JPG (26.73 KiB) Viewed 3754 times
Site Admin
Has thanked: 1012 times
Been thanked: 918 times
It's hard to tell how much plaster is missing in depth from the wall in picture 2.
It might be a good idea to bring it up to just below the level of the other plaster using hardwall and then give it a skim of finishing plaster.
The finish does not need to be perfect and so you can use it for practicing.
You will have to make sure that the plaster is level though and so grounds may be needed and a straight edge for the backing plaster.
Only-Me
Been thanked: 3 times
Post by Only-Me »
The bigger the tile.........the flatter the walls need to be.
Rather than faff about if your not into skimming the walls..........I'd get a plasterer in to sort it in a few hours..........rather than days it MAY take you :wink:
As for the painted wall...........stick some duct tape on.....leave for 30 mins. then pull of........if no paint :scratch: it should be ok, but to on the safe side.......just rough it up with coarse sandpaper :thumbright:
jozeffo
Has thanked: 45 times
Been thanked: 272 times
Post by jozeffo »
Have used the tanking system a couple of times. One customer now insists on it, the other said he wouldn't bother next time.
I would use bonding plaster because it sticks hard. Need to SBR bond before tiling though as per BAL recommendation.
With paint, I attack it with a shave hook or sharp screwdriver to score it back to the plaster and take off anything that flakes.
If you use a long level or straight edge when you square up the walls, you will give yourself a good surface to tile onto.
DIY_Johnny
Mr. Grumpy
Cheers guys,
Right, i have given the wall a good rubbing with the sander and coarse sand paper. Will score it back too. I see on the B&Q web site you can buy 8 different types of plaster (Thistle brand)
universal one coat
Dri-Coat
Board Finish
Multi Finish
Bonding
Hardwall
Dry wall adhesive
Browning
Some of the wall to be plastered is old thermolite, I think (black crumbley stuff). See picture 2
So should I just cover the wall with the Thistle Bonding coat and thats it?
1. Do I need a primer before I put on the Bonding coat. It seems to say that I use the ThistleBondit on a painted wall, is this necessary. See http://www.british-gypsum.com/PDF/LIT_T ... -Jan05.pdf
2. Can i just put the flexible tile adhesive straight on to the bonding coat for the non-shower area, or would I need a finishing plaster to smooth it up?
3. I need to patch up lots of bits and pieces in the other rooms two so if I use the bonding agent, can I just use the finishing plaster in this case?
Only-me:
very true about getting a plasterer in for a few hours. It would be much better and much quicker. But I fancy having a crack at doing it myself. Although I did try a ceiling a few years ago with that polycell smooth over. Was practically impossible, no clue how you guys do ceilings :shock: I ended up sanding the crap out of it to smooth it down :lol:
Only-Me
Post by Only-Me »
DO NOT TILE DIRECTLY ONTO BONDING/BROWNING PLASTER. :roll:
DIY_Johnny
Mr. Grumpy
ok, So should I use a finishing plaster first, then tile?
jozeffo
Post by jozeffo »
Easier to SBR bond an undercoat plaster. Skim plaster is weaker.
DIY_Johnny
Mr. Grumpy
Ok let me see if i have this right., sorry for the dumb questions but this is confusing to me :shock:
NON-SHOWER AREA
1. clean off the loose plaster / masonary / score paint etc
2. Seal walls??, do I need to?
3. Fill up large gaps with bonding plaster.
4. Cover all walls with BAL SBR Bond.
5. Using rapidset flex tile adhesive and put on the large tiles
SHOWER AREA
1. clean off the loose plaster / masonary / paint etc
5. Tank using BAL WP1 kit as per instructures
6. Tile
Is this ok chaps?
(UHM, there is about 15mm missing from the plaster in pict 2. Good point about practising the skimming plaster)
jozeffo
Post by jozeffo »
Not sure about stage 2. just use dilute PVA on the spots where you will plaster.
Everything else seems fine provided that it is consistent with the manufacturers instructions.
I personally wouldn't bother with the tanking but that's a matter of personal choice.
DIY_Johnny
Mr. Grumpy
Ok, cheers,
by the way if the wall is just quite rough but not missing great chunks of plaster how would I level that up? Its there a minimum depth I can use for the bonding plaster? Or should I use some other type?
I am told that the black stuff in picture 2 is clinker
Jim Dale
Contact:
bathroom
Post by Jim Dale »
1st you need a guy to re-plaster the walls and make sure he puts something on the walls before plastering, 2rd if you want a good job done in Tiling then get a guy who knows what hes talking about, i had my kitching re-tiled and its cost me £130 plus i had to buy the tiles but boy was it dead worth it, jim dale
DIY_Johnny
Mr. Grumpy
Re: bathroom
Jim Dale wrote:1st you need a guy to re-plaster the walls and make sure he puts something on the walls before plastering, 2rd if you want a good job done in Tiling then get a guy who knows what hes talking about, i had my kitching re-tiled and its cost me £130 plus i had to buy the tiles but boy was it dead worth it, jim dale
Howdy Jim,
If I was going to do all that there would be no need to come on to this site. I should be looking at the dolphin bathrooms web site or something :lol: :lol:
Take your point though, the pros are obviously going to do a better job than me. Point here is that I wish to learn another skill if possible
