Hard drives
thescruff
Has thanked: 360 times
Been thanked: 3735 times
Hard drives
Post by thescruff »
If I take the hard drive out of a not working computer, and stick it in one that is, what would happen. :roll:
Both are on 98se.
dave.m
Deceased 07-06-2012 R.I.P
Has thanked: 13 times
Been thanked: 318 times
Post by dave.m »
Scruff,
You can do it, instructions here how to and also on setting the BIOS:
http://www.cybertechhelp.com/tutorial/a ... rive-win98
Is there something on it that you want, or is it just to increase storage?
Seems a lot of trouble for an old OS like 98SE.
dave
thescruff
Post by thescruff »
I love 98se :lol:
Lots of reasons for wanting to keep it working.
I have an agfa photo scanner which you get drives for.
I have several programs which will only work on 98se, including a disc with thousands of old boilers.
The plan was I have two HDs in an old computer, and I was going to take them both out and fit the single HD from the defunct one.
dave.m
Post by dave.m »
I misunderstood your first post.
It would not work like that, because the MB would not recognise the OS on the newer HD.
What you could do is to leave the master HD in the working computer so that you will have 98SE still on it and install the HD from the defunct PC as a slave drive.
dave
thescruff
Post by thescruff »
Yes, I could take take the existing slave out and replace with the HD from the other computer.
scot-canuck
Has thanked: 247 times
Been thanked: 314 times
Post by scot-canuck »
repair install is the other trick (never usually works though sadly)
Return to “Computers”
