Revmping interior doors
Hi
My interior doors have suffered some damage from a over irate teenager. They are only the cheap hollow doors but I cannot afford to replace them all. SO I am looking for ways to repair either by filling or I thort maybe i could cover them with a new skin of very thin sheet plywood, (i think thats what I mean ). I realise that this could affect the opening of the door.
So advise please on the above or a recomended filler for the holes
Many thanks
Many thanks
- Has thanked: 823 times
- Been thanked: 3560 times
One way is to cut the damaged area back to solid area in the form of a rectangle. Cut a piece of thin MDF or hardboard big enough to allow you to pass it through the hole on the short edge. Drill a small hole and tie a bit of string through it and then carefully slide the and the repair patch through the hole and rotate it to cover the opening. Squirt a load of No More Nails or similar and pull the string to move the patch into position. Tie up the string in a sort of tourniquet to hold it firm whilst the glue sets.
When ready, fill the area between the patch and the door surface and skim it flush. This may take a couple of applications. Rub down and paint to suit.
If the doors are veneered it can be done but to be honest it would not be worth it.
If you would like I will come around and beat the sh*t out of the teenager to show him what his face will do to a door.
- Gas/Heating Expert
- Been thanked: 9 times
to do the job with a lot less work... you could cut a sheet of hardboard to the size of the door frame gap, rather than the size of the door...
so about 20mm less width than the door, and 10mm less height.
You can get the sheets cut to size at most suppliers.
then just stick onto the door using "no more nails" you will have to refix the handle through the new skin.
Last edited by Hinton Heating on Sun Mar 25, 2007 4:41 pm, edited 2 times in total.
- sparkydude
- Has thanked: 2 times
- Been thanked: 149 times
You could just get some expanding foam filer and pump this into the door cavity. wait to dry then just cut back, skin of flexible car body filler over it , light sanding, paint and job done.
Nick
Nick
- dirtydeeds
- Craftsman Carpenter
