- Ultimate Handyman Forum Index SHOW CASE- A place to show us your work Rogues Gallery
- It is currently Wed Apr 23, 2025 7:05 am
Why I got into DIY!
- Mr. Grumpy
- Has thanked: 25 times
- Been thanked: 109 times
Why I got into DIY!
Post by DIY_Johnny »
One of the reasons I got into DIY was the seemly poor standards I saw in my flat when it was renovated by the previous owner. He gave me his receipts and he paid a fortune for a lot of work. It was done in 2004 / 5 perhaps. It was done by a registered company it looks like.
- This was put in after the boxing. Too low to plug anything in with catchinh the cable on the boxing
- Socket.jpg (40.02 KiB) Viewed 7482 times
- Well as least it recessed :-)
- Socket 2.jpg (52.45 KiB) Viewed 7482 times
- The 'carpenters' work
- Door 1.jpg (20.2 KiB) Viewed 7487 times
- The 'carpenters' work. I have no idea what happened here
- Door 2.jpg (15.76 KiB) Viewed 7487 times
- The 'carpenters' work. Door never closed even before paining. Still doesn't
- Door 3.jpg (18.37 KiB) Viewed 7487 times
- This is annoyong as its loose and water dribbles down the whole. The stop could have been put on the wall
- Doorstop.jpg (58.79 KiB) Viewed 7487 times
- Bear in mind one light is for the hall and other for the lounge. They should be the other way round but cables wouldn't reach to other terminal
- Light Switch 2.jpg (53.11 KiB) Viewed 7487 times
- This is how far I can pull the dimmer out!
Either Black or red insulation was nicked so were just patched with tape - Light Switch 1.jpg (47.25 KiB) Viewed 7487 times
- Every room has these glass panels above the doors. I spent an age scraping the paint off but eventually gave up!
- Painting 1.jpg (36.82 KiB) Viewed 7487 times
- The 'painter' just used left over emulsion paint for the bathroom.
- Painting Bathroom.jpg (38 KiB) Viewed 7487 times
- Surley there is no need for a line like this!
- Wall Paper.jpg (32.4 KiB) Viewed 7487 times
DIY_Johnny
speed
- thescruff
- Has thanked: 360 times
- Been thanked: 3735 times
thescruff
Hitch
- Mr. Grumpy
There are loads of things on my "to do" list.
I hate buying a place where it has been "renovated" as it just adds a lot to the price and usually its done on the cheap, made to look cosmetically pleasing for purposes of sale. I may sell this place sometime and buy a place that requires a lot of work. Thay way you can put in your own kitchen bathroom etc .
Actually when I bought my place the flat on sale down stairs is identical but some granny owned it and hadn't done a thing with it in 30 years. Would have been a better buy in hindsight.
Live and learn I suppose
DIY_Johnny
- Deleted-user-3
- BANNED
- Has thanked: 101 times
- Been thanked: 157 times
Post by Deleted-user-3 »
all depends on how the property was renovated... excellent philosophy though...
problem seems to be the developers who purchase propert that hasnt been modernised in 30 years just literally give em a lick of paint and then once in you discover it wanted a lot more...
there are still some cracking properties to be had if one is prepared to go the extra mile with the renovation but unfortunately there doesnt seem to be the profits there were a few years ago...
like your style, keep it up one bite at a time :)
Deleted-user-3
- Mr. Grumpy
If you are doing for investment, I can see why people are do it, but for a home its a pain in the ass when some has coated the place in B&Q paint with cleaning the walls.
Drives me mad trying to explain that to my gf who is prepared to pay 25k extra cos they gave it a fresh coat of paint
DIY_Johnny
- Has thanked: 178 times
- Been thanked: 19 times
Woodchip paper hides a lot,the doors i would remove the wiggley bit and add some fresh timber2x1 glue and nail and plane down ,and the warped door you can brace some timber over it to force the warp out or remove the top door stop and push it in and put a screw into the top of the frame to hold the door in and leave for a couple of days but you probably know that anyway.Also the paint on the window they say wd40 is good to soften up the paint on the glass to make it easy to remove.
diyguys
- Mozzy Jones
Post by Mozzy Jones »
Thanks for sharing, those colours sure are artistic. Everything else seemed OK.
Mozzy
Mozzy
Mozzy Jones
- Deleted-user-3
- BANNED
or buy a couple of new doors @ 12 quid each....diyguys wrote:Woodchip paper hides a lot,the doors i would remove the wiggley bit and add some fresh timber2x1 glue and nail and plane down ,and the warped door you can brace some timber over it to force the warp out or remove the top door stop and push it in and put a screw into the top of the frame to hold the door in and leave for a couple of days but you probably know that anyway.Also the paint on the window they say wd40 is good to soften up the paint on the glass to make it easy to remove.
nitromors is even better at softening up paint...
Deleted-user-3
you can buy some cheap doors but the original doors when refurbed are better quality,also if when you are selling a lot of people like the old doors also 2x1 is cheaper than a new door , and i don't like nitro paint stripper you end up taking the paint of the wood also unless you are extremely careful.
diyguys
- Mr. Grumpy
My whole place is keep together with wood chip
Only thing I like about the doors is that the handles are high up (1.3m). Don't understand when we have to cater everything now-a-days for either midgets or disabled people, even in your own home. I hate the new socket height under building regs for domestic regulations
If the munchkins want an accessable height for them, let them pay my mortgage
DIY_Johnny
- Deleted-user-3
- BANNED
high up handles? does that mean all the doors are hung upside down?
having just had another quick gander.... it would certainly appear so...
one way round it i suppose...
Deleted-user-3
- Mr. Grumpy
Doors are probably the original ones. They are the right way round as all flats are the same, unless when they built the block the carpenters put all doors in upside down.
DIY_Johnny
- Deleted-user-3
- BANNED
stranger things have happened...
Deleted-user-3
