Why I got into DIY!
This is where you can post pictures of extremely poor workmanship, whether it is done by a dodgy tradesman or by an incompetent DIY'er. Instructions on how to post pictures can be found in here.
DIY_Johnny
Mr. Grumpy
Has thanked: 25 times
Been thanked: 109 times
Why I got into DIY!
Post by DIY_Johnny »
One of the reasons I got into DIY was the seemly poor standards I saw in my flat when it was renovated by the previous owner. He gave me his receipts and he paid a fortune for a lot of work. It was done in 2004 / 5 perhaps. It was done by a registered company it looks like.
This was put in after the boxing. Too low to plug anything in with catchinh the cable on the boxing
Well as least it recessed :-)
Socket 2.jpg (52.45 KiB) Viewed 7473 times
The 'carpenters' work
Door 1.jpg (20.2 KiB) Viewed 7478 times
The 'carpenters' work. I have no idea what happened here
Door 2.jpg (15.76 KiB) Viewed 7478 times
The 'carpenters' work. Door never closed even before paining. Still doesn't
Door 3.jpg (18.37 KiB) Viewed 7478 times
This is annoyong as its loose and water dribbles down the whole. The stop could have been put on the wall
Bear in mind one light is for the hall and other for the lounge. They should be the other way round but cables wouldn't reach to other terminal
Light Switch 2.jpg (53.11 KiB) Viewed 7478 times
This is how far I can pull the dimmer out!<br />Either Black or red insulation was nicked so were just patched with tape
Light Switch 1.jpg (47.25 KiB) Viewed 7478 times
Every room has these glass panels above the doors. I spent an age scraping the paint off but eventually gave up!
Painting 1.jpg (36.82 KiB) Viewed 7478 times
The 'painter' just used left over emulsion paint for the bathroom.
Painting Bathroom.jpg (38 KiB) Viewed 7478 times
Surley there is no need for a line like this!
Wall Paper.jpg (32.4 KiB) Viewed 7478 times
speed
Has thanked: 35 times
Been thanked: 257 times
Post by speed »
wow Door 2.jpg :shock:
thescruff
Has thanked: 360 times
Been thanked: 3735 times
Post by thescruff »
The tape on the dimmer cables is certainly for ID.
Hitch
Has thanked: 77 times
Been thanked: 335 times
Post by Hitch »
That door is special, did he plane it to size with an angle grinder?
Have you tried swapping doors 2/3 over :lol:
DIY_Johnny
Mr. Grumpy
There are loads of things on my "to do" list.
I hate buying a place where it has been "renovated" as it just adds a lot to the price and usually its done on the cheap, made to look cosmetically pleasing for purposes of sale. I may sell this place sometime and buy a place that requires a lot of work. Thay way you can put in your own kitchen bathroom etc .
Actually when I bought my place the flat on sale down stairs is identical but some granny owned it and hadn't done a thing with it in 30 years. Would have been a better buy in hindsight.
Live and learn I suppose :wink:
Deleted-user-3
Has thanked: 101 times
Been thanked: 157 times
Post by Deleted-user-3 »
all depends on how the property was renovated... excellent philosophy though...
problem seems to be the developers who purchase propert that hasnt been modernised in 30 years just literally give em a lick of paint and then once in you discover it wanted a lot more...
there are still some cracking properties to be had if one is prepared to go the extra mile with the renovation but unfortunately there doesnt seem to be the profits there were a few years ago...
like your style, keep it up one bite at a time :)
DIY_Johnny
Mr. Grumpy
If you are doing for investment, I can see why people are do it, but for a home its a pain in the ass when some has coated the place in B&Q paint with cleaning the walls.
Drives me mad trying to explain that to my gf who is prepared to pay 25k extra cos they gave it a fresh coat of paint ::b
diyguys
Has thanked: 178 times
Been thanked: 19 times
Post by diyguys »
Woodchip paper hides a lot,the doors i would remove the wiggley bit and add some fresh timber2x1 glue and nail and plane down ,and the warped door you can brace some timber over it to force the warp out or remove the top door stop and push it in and put a screw into the top of the frame to hold the door in and leave for a couple of days but you probably know that anyway.Also the paint on the window they say wd40 is good to soften up the paint on the glass to make it easy to remove.
Mozzy Jones
Been thanked: 1 time
Post by Mozzy Jones »
Thanks for sharing, those colours sure are artistic. Everything else seemed OK. :wink:
Mozzy
Deleted-user-3
diyguys wrote:Woodchip paper hides a lot,the doors i would remove the wiggley bit and add some fresh timber2x1 glue and nail and plane down ,and the warped door you can brace some timber over it to force the warp out or remove the top door stop and push it in and put a screw into the top of the frame to hold the door in and leave for a couple of days but you probably know that anyway.Also the paint on the window they say wd40 is good to soften up the paint on the glass to make it easy to remove.
or buy a couple of new doors @ 12 quid each....
nitromors is even better at softening up paint... :wink:
diyguys
Post by diyguys »
you can buy some cheap doors but the original doors when refurbed are better quality,also if when you are selling a lot of people like the old doors also 2x1 is cheaper than a new door , and i don't like nitro paint stripper you end up taking the paint of the wood also unless you are extremely careful.
DIY_Johnny
Mr. Grumpy
My whole place is keep together with wood chip
Only thing I like about the doors is that the handles are high up (1.3m). Don't understand when we have to cater everything now-a-days for either midgets or disabled people, even in your own home. I hate the new socket height under building regs for domestic regulations :wink:
If the munchkins want an accessable height for them, let them pay my mortgage :lol:
Deleted-user-3
high up handles? does that mean all the doors are hung upside down?
having just had another quick gander.... it would certainly appear so...
one way round it i suppose...
DIY_Johnny
Mr. Grumpy
Doors are probably the original ones. They are the right way round as all flats are the same, unless when they built the block the carpenters put all doors in upside down. :lol:
Deleted-user-3
stranger things have happened... :lol:
Return to “Rogues Gallery”
