Dimmer switch
Locked
misterk
Dimmer switch
Post by misterk »
Is it possible to use a dimmer switch on a two way or three way lighting arrangement?
I have looked here- http://www.ultimatehandyman.co.uk/DIMMER_SWITCH.htm
But it does not say :?
markysparky
Electrician
Contact:
Re: Dimmer switch
Post by markysparky »
Yes you can but only put the dimmer on one switch but not both.
The diagram actually shows a 2 way switch being used with 1 way wiring. The L2 shown on the diagram is used for 2 way.
misterk
Post by misterk »
Thanks for the reply, I thought I better check before I go out and buy one!
Locked
Return to “Lighting”
