Can I tile on this plasterboard?
- dinoken
- Has thanked: 8 times
Hi all!
I am new to this DIY business and would like your expert opinion on this. I am about to embark on my first tiling project and after removing the wooden slats covering the wall, this is the condition of the 9mm thick plasterboard. I am hoping to tile from floor to ceiling with some ceramic tiles (so not too heavy).
Do you think this will take the weight?
Would getting someone in to plaster it help?
Many thanks
Many thanks
- Been thanked: 12 times
Re: Can I tile on this plasterboard?
That board is fooked mate. Rip it off and re-board. Quick, easy, cheap job and you've got a perfect new surface to tile onto.
- These users thanked the author All The Gear for the post:
- dinoken
- Has thanked: 820 times
- Been thanked: 3521 times
And if it is a wet area use Aquapanel or similar cement board.
- dinoken
dinoken wrote:Excellent.
I've bought 5x 8by4 moisture resistant plaster boards. I just hope they fit up the stairs!
You might be able to use this technique- http://www.youtube.com/watch?v=J-0EfIDVcLQ
- These users thanked the author ultimatehandyman for the post:
- dinoken
- Has thanked: 39 times
- Been thanked: 621 times
I didn't watch vid so sorry if this is what it was about.......
Cut board to height downstairs. Then make a cut across the back, halfway, with stanley knife. Fold the front in on itself. carry upstairs, put against your wall and fold it back out and up in position and fix.
- dinoken
