Computer wont shut down
Mick Coleman
Has thanked: 2 times
Post by Mick Coleman »
hi
im runing windows xp home
On an Advent 900 computer
When i tell the computer to shut down nothing happens
i have to turn it off at the switch
Mick
PAINTER 1
skiking
Been thanked: 4 times
Post by skiking »
Is that every time you want to close down ?
I take it you are doing Start / Shut Down then selecting Shut Down from the drop down options.
My initial reaction is there is a process that is running that the shut down process can't stop. If this has only just started happening I would try and boot up using a previously successful load. I think that option is available on the Home edition
Mick Coleman
RESTORE
thanks i will try it
PAINTER 1
RichieP
UHM Super Moderator
Has thanked: 4 times
Been thanked: 12 times
Post by RichieP »
Plenty of things to try here
Mick Coleman
THANKS
Thanks i restored it back to a later date
alls well now
Thank you
Mick
PAINTER 1
thepid
Post by thepid »
have similar problems with mine as well
skiking
Post by skiking »
Have you tried the above suggestions ?
Mick Coleman
RESTORED
yes i restored it back to a later date
i worked
PAINTER 1
skiking
Post by skiking »
sorry, MC was replying to thepid :wink:
fire1
Post by fire1 »
I got the same problem with my pc too before a month.i tried changing the BIOS,after that I tried to restore back to a later date and its worked fine.
Has thanked: 740 times
Been thanked: 2355 times
fire1 wrote:I got the same problem with my pc too before a month.i tried changing the BIOS,after that I tried to restore back to a later date and its worked fine.
wow back to the future part one two and three :grin: :grin: :wink:
[or should that be forward to the past :wink: ]
Return to “Computers”
