Adding a halogen light to a loop-in circuit
Locked
Fraser
Post by Fraser »
Hi
I would like a bit of advice about adding a halogen fitting to an existing loop-in circuit.
I was thinking of adding a junction box in the circuit and running a cable to the halogen light and another to the new switch. I think it'll work but I'd like to know if you think it is safe?
(I've drawn a couple of very basic diagrams to help decipher my description)
The halogen fitting is 5x35w so will 1mm2 twin&earth be sufficient?
In case you ask, the reason I wasn't going to add the halogen as a loop-in is ease of access but if you have any other suggestions for methods I would be pleased to hear them.
current circuit
current circuit
Current circuit.jpg (9.58 KiB) Viewed 2141 times
Proposed circuit
Proposed circuit
Proposed circuit.jpg (12.48 KiB) Viewed 2141 times
Site Admin
Has thanked: 1012 times
Been thanked: 918 times
I can't see a problem with it, apart from any junction box needs to be accessable and so this is not an ideal solution if the junction box cannot be accessed.
ban-all-sheds
BANNED
Been thanked: 2 times
Post by ban-all-sheds »
Breaking into loop-in lighting circuits is the reason they make 4-terminal JBs, so it's perfectly OK.
Yes, JBs need to be accessible, but that term is a bit vague - if you can get to it via a downlight hole in the ceiling, or by lifting the floor above, then you'll be no worse off than millions of existing houses.
If there is no access through the ceiling, and the floor above cannot be lifted, then you have a problem.
As for cable, use whatever size the existing lighting circuit is wired in.
Are you aware of the notification requirements if this is in a kitchen/bathroom/shower-room etc?
I'm sorry - I can't come in to work today, the voices are telling me to stay at home and clean the guns.
[size=9][color=white].[/color] [/size]
Fraser
Post by Fraser »
The JB would be accessible via a floorboard from the bedroom above.
I am fitting the light in a kitchen and I am not really aware of notification re: kitchens but I'll search the forum as I'm sure it'll be around here.
Thanks for your replies.
Fraser
Post by Fraser »
Found your helpful post about notification here - diy-electrical-work-and-the-law-t6296.html
Stoday
Deceased 21-10-2011 R.I.P
Has thanked: 8 times
Been thanked: 90 times
Post by Stoday »
ban-all-sheds wrote: As for cable, use whatever size the existing lighting circuit is wired in.
Like 3/029? :lol:
Rich-Ando
Pro Tradesman
Has thanked: 135 times
Been thanked: 304 times
Post by Rich-Ando »
Like 3/029? :lol:
Ha Ha! :lol: Image
ban-all-sheds
BANNED
:hello2:
Locked
Return to “Lighting”
