Looking for good quality tubing as my system keeps popping up with leaks (2/3 years old now). Tube size is 6mm external, 4 internal.
Also are they any small jubilee clips for holding this tubing in place, currently using cable ties, but not ideal and does not always stop leaks.
I usually use a jar of very hot water to soak the end of the tube for 10 seconds before making the connection, are they a better way?
Best,
Graham.
- Ultimate Handyman Forum Index Other DIY Gardeners World
- It is currently Sun Apr 06, 2025 8:18 am
Micro Irrigation System
graham101
- arco_iris
- Has thanked: 184 times
- Been thanked: 535 times
Re: Micro Irrigation System
This would seem to indicate that you are using plastic tubing - I have always found rubber tubing to be better.graham101 wrote:I usually use a jar of very hot water to soak the end of the tube for 10 seconds before making the connection
Rubber does not need softening, as it grips the connectors it doesn't need clips, and being more flexible is less prone to springing leaks.
If you get the chance, on holiday or whatever, you'll find a wide selection of components & adaptors in Spanish, possibly south of France, Portugese DIY stores, where they use far more of it than we do in UK.
arco_iris
- Has thanked: 1415 times
- Been thanked: 4031 times
Hozelock system is good... BUUUUUTTTT expensive.
- arco_iris
Plastic tubing.wine~o wrote:Hozelock system is good...
Concur - you're not wrong, wine~o. Depending on what OP wants to do, an upturned 2 litre pop bottle, with a small hole drilled in the lid, stuck in each growbag, might suffice.wine~o wrote:BUUUUUTTTT expensive.
The problem we have found is that we set up the irrigation timer two weeks before we go abroad and adjust it - then while we away either the temperature soars or we have a cold snap. It rarely works unattended.
arco_iris
