Micro Irrigation System
graham101
Has thanked: 90 times
Been thanked: 1 time
Post by graham101 »
Looking for good quality tubing as my system keeps popping up with leaks (2/3 years old now). Tube size is 6mm external, 4 internal.
Also are they any small jubilee clips for holding this tubing in place, currently using cable ties, but not ideal and does not always stop leaks.
I usually use a jar of very hot water to soak the end of the tube for 10 seconds before making the connection, are they a better way?
Best,
Graham.
arco_iris
Has thanked: 184 times
Been thanked: 535 times
Re: Micro Irrigation System
Post by arco_iris »
graham101 wrote:I usually use a jar of very hot water to soak the end of the tube for 10 seconds before making the connection
This would seem to indicate that you are using plastic tubing - I have always found rubber tubing to be better.
Rubber does not need softening, as it grips the connectors it doesn't need clips, and being more flexible is less prone to springing leaks.
If you get the chance, on holiday or whatever, you'll find a wide selection of components & adaptors in Spanish, possibly south of France, Portugese DIY stores, where they use far more of it than we do in UK.
These users thanked the author arco_iris for the post:
graham101
wine~o
Has thanked: 1415 times
Been thanked: 4031 times
Post by wine~o »
Hozelock system is good... BUUUUUTTTT expensive.
graham101
arco_iris
Post by arco_iris »
wine~o wrote:Hozelock system is good...
Plastic tubing.
wine~o wrote:BUUUUUTTTT expensive.
Concur - you're not wrong, wine~o. Depending on what OP wants to do, an upturned 2 litre pop bottle, with a small hole drilled in the lid, stuck in each growbag, might suffice.
The problem we have found is that we set up the irrigation timer two weeks before we go abroad and adjust it - then while we away either the temperature soars or we have a cold snap. It rarely works unattended.
Return to “Gardeners World”
