Are large 1000mm kitchen Wall Cabinets A Good Choice?
ahll
Has thanked: 87 times
Been thanked: 3 times
Post by ahll »
I am not sure of this is the right forum..if not then please move accordingly thanks
I am looking to put up some kitchen cabinets in my utility to add extra storage space. I would like to do this as economically as I can as I still have the kitchen and bathroom to do. I was thinking about putting up 3* 1000 units but I vaguely remember reading somewhere that they can bend.
Do you regularly use 1000 until or is it better to use smaller ones?
Does anyone have experience of using B&Q Cooke & Lewis 1000 x 900 or 1000 x 720mm
I believe they are 18mm thick.
Any recommendation of cabinets to consider welcome
Power to the little people
arco_iris
Has thanked: 184 times
Been thanked: 535 times
Re: Are large 1000mm kitchen Wall Cabinets A Good Choice?
Post by arco_iris »
Yes they sag, you always put more weight in them than you think. And the shelf will probably only be 15mm so thats worse.
It would be possible to strengthen them (a sheet of particle board or mdf let into the back recess) but a much better solution would be 2 x 500mm units or if you have space, 2 x 600mm.
Rorschach
Has thanked: 126 times
Been thanked: 1045 times
Post by Rorschach »
What is the price difference? If 2 x 500mm is only slightly more expensive than 1 x 1000mm then go for it. When we did our kitchen the 1000mm unit was only a few £'s more expensive than a single 500mm, so it would have been very expensive to go that way. I went with the 1000mm and added extra support myself, no sag on the main carcass, minimal sag on the shelf.
Job and Knock
Old School Chippie
Has thanked: 742 times
Been thanked: 1573 times
Post by Job and Knock »
I'm with Arco on this one - longer cabinets are far more prone to sagging in the middle and simply cannot carry the same weight as two 500mm cabinets, so taking a longer term view I'd draw the line at 600mm length or less on upper cabinets
Has thanked: 1415 times
Been thanked: 4031 times
I've got a 1000mm wall unit, has a central divide, no sign of sagging and it's been up 10 years.
Job and Knock
Old School Chippie
But how much load is it carrying?
Job and Knock wrote:But how much load is it carrying?
RHS is fully loaded with china, LHS fairly light stuff.
Sheraton units though... dunno if that makes a difference.
Rorschach
Post by Rorschach »
Is it a full divide or just a post in the middle?
Rorschach wrote:Is it a full divide or just a post in the middle?
Proper full divide, but still a 1000 mm unit
Rorschach
Post by Rorschach »
That is probably helping then. My 1000mm units only have a central post, that was part of the reason I decided to add extra support.
Return to “Kitchen Fitting”
