Top hat spacers for a plastic cover
topconker
Has thanked: 8 times
Been thanked: 2 times
Post by topconker »
I have a Mountfield mower I am doing up and have noticed one of the inserts in the top mouling is missing. I've no idea what they are called, maybe top hat inserts but can't find anything on the net. Does anyone know what they are called? They have an ID of 8mm and OD of 10mm with a flange that sits against the plastic.
Cheers,
TC
ayjay
Has thanked: 458 times
Been thanked: 1708 times
Post by ayjay »
You're on the right lines with "Top Hat Washers" (they should always be used when fixing mirrors with dome-head screws, which is how I know): also called "Shoulder Washers" apparently.
These people appear to have a selection of sizes, but they're in Australia, someone must have similar in the UK:- https://www.supfast.com.au/washers-and- ... g-washers/
topconker
Post by topconker »
Thanks ayjay, hadn't thought about calling them shoulder washers. I have a picture of something similar but not sure how ro post it here.
topconker
Post by topconker »
yes I do!
topconker
Post by topconker »
I've found some nylon ones, wonder if they may do the job as there's no fuel in the area that could cause a problem?
Has thanked: 831 times
Been thanked: 3630 times
All the ones I found are bags of 500, admittedly they are only £12 but it is a lot for only needing one
topconker
Post by topconker »
Hi DWD where did you find them?
topconker
Post by topconker »
Thanks DWD
Bob225
Has thanked: 106 times
Been thanked: 882 times
Post by Bob225 »
What model mower is it, many places have expanded diagrams with part listings
eg. https://www.worldofmowers.co.uk/mountfield-spare-parts
topconker
Post by topconker »
Thanks Bob, found that, but it only shows the cover which I guess has the inserts fitted as part of the unit
Bob225
Post by Bob225 »
Do you mean a plastic body cover ? as in a plastic stand off ? what model is it ??
topconker
Post by topconker »
Hi Bob, it's the plaqstic that's held on by 3 self tappers.
Model number RM55.
I's not the standoffs, just the screws that hold it in position.
jaeger
Has thanked: 40 times
Been thanked: 76 times
Post by jaeger »
topconker
Post by topconker »
Thanks jaeger, those are similar to what I have ordered. Here's a couple of photos showing where the inserts fit and a close up of one.
Inserts_Pic 002.JPG (149.53 KiB) Viewed 4011 times
Inserts_Pic 001.JPG (147.55 KiB) Viewed 4011 times
