Messy wires
Cannyfixit
Has thanked: 102 times
Been thanked: 183 times
Messy wires
Post by Cannyfixit »
Is there such a thing as cable ties for dashboards,I have a dash cam, a sat nav And I’m about to install a reverse camera
I have a a bit of a thing with wires and wanted to tidy them up
Has thanked: 48 times
Been thanked: 2606 times
Messy wires
There is no such thing as cable ties for............................(Any specific item)
I had a similar "problem" Dash cam, Sat nav, and Reverse camera, I just used small cable ties to group them together, doesn't hide any of them, but keeps the cables looking like one cable.
Cannyfixit (Sun Oct 20, 2019 10:14 pm)
jaeger
Has thanked: 40 times
Been thanked: 76 times
Messy wires
Post by jaeger »
Spiral wire wrap?
Wire wrap (Small).jpg (35.8 KiB) Viewed 3126 times
These users thanked the author jaeger for the post:
camallison
Has thanked: 127 times
Been thanked: 108 times
Messy wires
Post by camallison »
jaeger wrote: Sun Oct 20, 2019 9:13 am Spiral wire wrap?
Might be a bit stiff though, resulting in large curves rather than neat run.
Colin
mikew1972
Has thanked: 11 times
Been thanked: 110 times
Messy wires
Post by mikew1972 »
Cable tie anchor / mount / adhesive base?
Mike
Dave54
Has thanked: 1300 times
Been thanked: 1175 times
Messy wires
Post by Dave54 »
The only other thing I can think of is using old fashioned "lacing cord" Haven't used it for many years myself, but it does have it's uses.
https://www.electronics-notes.com/artic ... lacing.php
These users thanked the author Dave54 for the post:
Cannyfixit
Messy wires
Found these on Fleabay https://rover.ebay.com/rover/0/0/0?mpr ... 2039797519
Looks like they might work
Bob225
Has thanked: 106 times
Been thanked: 882 times
Messy wires
Post by Bob225 »
Cannyfixit wrote: Sun Oct 20, 2019 10:19 pm Found these on Fleabay https://rover.ebay.com/rover/0/0/0?mpr ... 2039797519
they work ok but can come loose overtime and make a mess of the plastics prep with IPA is a must, a bit of split loom aka convoluted tube (make sure its the split stuff) does the trick
personally I like to hardwire items or at least hide them and use inline sockets, things like cameras pull such low current you can tap any switch live circuit within reason - be aware that in the male connector (that you plug in the aux 12v socket) there is usually a voltage dropper built in dropping it to 5v or 3.3v
Cannyfixit (Tue Oct 22, 2019 6:32 am)
Has thanked: 1415 times
Been thanked: 4031 times
Messy wires
I would just try to "dress" the wires/cables as best you can. Surprising how easy it is to hide my 2 dashcam cables.
Cannyfixit
Messy wires
wine~o wrote: Mon Oct 21, 2019 5:18 pm I would just try to "dress" the wires/cables as best you can. Surprising how easy it is to hide my 2 dashcam cables.
I did just this in my lunch break yesterday,I’ve run the dash cam wire behind the head liner and down the A pillar ,looks much better but when the rear camera arrives I’m going to have to look at tapping into the fuse box otherwise I’ll have a twin socket and two plugs to deal with
Cannyfixit
Messy wires
Bob225 wrote: Mon Oct 21, 2019 4:42 pm
Cheers Bob,I’m aware of the voltages I’m planning on running a extra 12v double socket from the fuse box and securing it behind the plastics somewhere :thumbright:
