- It is currently Mon Apr 21, 2025 2:03 pm
Old Red/Black Cable
- Has thanked: 16 times
- Been thanked: 2 times
Old Red/Black Cable
Hello,
I have discovered a 100 ft Roll of 2.5mm Twin/Earth cable (Pre EU/UK) tucked away.
It is the Red/Black.
Now we have left the EU would it be legal to use it in my own garage?.
Thank you.
Thank you.
Onar
- arco_iris
- Has thanked: 184 times
- Been thanked: 535 times
Old Red/Black Cable
I expect the professional electricians on here will have comment to make, but to the best of my knowledge, BS7671 - the wiring regulations, which are not law - does not specifically say it can't be used.
However, if the rest of your house is already in the new "harmonised" colours, you should technically put a sticker on the consumer unit that says mixed colours are in use in the building, you can get these online in small packs. It works the other way, you see, when you can only purchase new spec. cable to do a repair in an old building.
Alternatively, you can buy yourself some blue sleeving & some brown sleeving and slide this over your black/red inside each socket backbox, light switches, and junction boxes. I believe this would make it compliant.
The pros are under pressure from their trade/certification bodies to use the new colours so where you might come up against aggro is if your installation needs to be tested & officially certified.
arco_iris
ericmark
- Has thanked: 118 times
- Been thanked: 219 times
Old Red/Black Cable
Over sleeving is largely irrelevant. Red & black was the correct colour to be used IMHO.
As for anybody commenting its a bad idea and not compliant - show them the door.
Neelix
- Has thanked: 48 times
- Been thanked: 2608 times
Old Red/Black Cable
You might want to sell it on ebay.
- Argyll
- Has thanked: 1194 times
- Been thanked: 584 times
Old Red/Black Cable
I wish I'd known this when I forked out on a new reel last year when wiring my shed. I have a full reel of the old stuff that someone told me I couldn't use
Argyll
Old Red/Black Cable
How would anyone know if you used it in your own place? But same advice, sell it on ebay, its not quite silly money but I bet its much more than you paid for it.
- Argyll
Old Red/Black Cable
I just thought as it's connected to the CU and if I ever sell my house it might be highlighted on the report so thought it best to play safe. I need to rewire my kitchen at some point. I might use it with the new sleeving.Someone-Else wrote: ↑Wed Dec 29, 2021 5:53 pm How would anyone know if you used it in your own place? But same advice, sell it <span class="skimwords-potential">on ebay</span><span style="position: absolute;"></span><span style="position: absolute;"></span>, its not quite silly money but I bet its much more than you paid for it.
Argyll
Onar
- arco_iris
Old Red/Black Cable
Quite likely - but weighty, so carriage/postage to take into account.Someone-Else wrote: ↑Wed Dec 29, 2021 5:53 pm How would anyone know if you used it in your own place? But same advice, sell it <span class="skimwords-potential">on ebay</span><span style="position: absolute;"></span><span style="position: absolute;"></span>, its not quite silly money but I bet its much more than you paid for it.
Argyll, as Neelix didn't object as I thought he might, just use it and apply a sticker.
arco_iris
- Has thanked: 10 times
- Been thanked: 194 times
Old Red/Black Cable
The only real issue is , will the cable pass a test ect
Other than that label CCU , mine is labelled for this reason
Chippo1
- kellys_eye
- Has thanked: 357 times
- Been thanked: 1790 times
Old Red/Black Cable
Post by kellys_eye »
What kind of useless electrician WOULDN'T recognise red/black as opposed to brown/blue FFS? How is the different colour supposed to be 'dangerous'? This is akin to a garage mechanic not knowing the difference between petrol and diesel.
kellys_eye
- Razor
- Has thanked: 483 times
- Been thanked: 1251 times
Old Red/Black Cable
Old coloured cable goes well on ebay.
It means tradesmen that aren't sparkles can fit new circuits and claim it was existing
Razor
Old Red/Black Cable
As a spark I’m expected to add a warning label on a fuseboard if both old and new colours are used.
After about 18 years since the colour change we need to stop adding POINTLESS labels - I stopped a few years ago
If you don’t know that red is live or brown is live you deserve to hurt yourself
Neelix
- Argyll
Old Red/Black Cable
For the non sparks out there it's easy to remember 'black and blue'Neelix wrote: ↑Wed Dec 29, 2021 10:27 pm As a spark I’m expected to add a warning label on a fuseboard if both old and new colours are used.
Argyll
