USB heated portable electric blanket
Zacccc
Has thanked: 191 times
Been thanked: 8 times
Post by Zacccc »
I want to buy a USB heated portable electric blanket to use while watching TV. Is it possible to run this via a mains adapter with USB ports or are these ports only for charging items with USB connectors? Thanks.
Has thanked: 48 times
Been thanked: 2606 times
Depends on the adaptor you use. Most should work.
Zacccc (Sun Oct 09, 2022 10:30 pm)
ericmark
Has thanked: 118 times
Been thanked: 785 times
Post by ericmark »
As I said on the other forum "I am sure it is, but USB is max around 2 amp, at 5 volt, so 10 watt, this is so little heat, only likely to work as a hand warmer." I was looking at a 4 x USB plug 4 x 13A connector block, and noted the whole 4 were only rated 2 amp, where a wall socket with USB each is normally rated at 2.1 amp, so does depend on the adaptor as already said.
These users thanked the author ericmark for the post:
Zacccc (Mon Oct 10, 2022 10:06 pm)
Zacccc
Post by Zacccc »
ericmark wrote: Mon Oct 10, 2022 7:56 pm As I said on the other forum "I am sure it is, but USB is max around 2 amp, at 5 volt, so 10 watt, this is so little heat, only likely to work as a hand warmer." I was looking at a 4 x USB plug 4 x 13A connector block, and noted the whole 4 were only rated 2 amp, where a wall socket with USB each is normally rated at 2.1 amp, so does depend on the adaptor as already said.
Ok, thanks for that. I think then that I won't invest in one if they give so little heat.
Neelix
Been thanked: 219 times
Post by Neelix »
Zacccc wrote: Mon Oct 10, 2022 10:07 pm
But bear in mind just a blanket will help reduce your heating costs
These users thanked the author Neelix for the post:
Zacccc (Tue Oct 11, 2022 5:30 pm)
Has thanked: 1415 times
Been thanked: 4031 times
When I was a lad we would huddle around a candle when it was cold
When it got really cold we would light the candle...
Zacccc
Post by Zacccc »
wine~o wrote: Tue Oct 11, 2022 5:20 pm When I was a lad we would huddle around a candle when it was cold
You had a candle! ... Luxury!
My dad used to suck a mint and we'd sit round his tongue to get warm!
OnlyMe
Approved Electrician
Has thanked: 225 times
Been thanked: 664 times
Post by OnlyMe »
I have worked on a few houses that were fire damaged due to candles and some involved deaths. I would never light a candle in my house.
Rorschach
Has thanked: 126 times
Been thanked: 1045 times
Post by Rorschach »
If you are going to plug it into the mains get a proper heated blanket, they will put out much more heat. You can also get heat pads that you lie on, or even just get a cheap electric blanket designed for a bed, lay on that and put a normal blanket over the top of you.
My partner does WFH a lot now and the flat is a bit chilly in the winter. Rather than put the heating on I bought a heating pad which we put on her office chair, she then puts a blanket over her shoulder and legs. Keeps her toasty warm and only draws 10W on low which is often enough but if its really cold it can go up to 45W on high.
Zacccc (Wed Oct 12, 2022 10:20 pm)
Return to “Electric Forum UK”
