- It is currently Thu Apr 03, 2025 4:59 pm
USB heated portable electric blanket
- Has thanked: 191 times
- Been thanked: 8 times
I want to buy a USB heated portable electric blanket to use while watching TV. Is it possible to run this via a mains adapter with USB ports or are these ports only for charging items with USB connectors? Thanks.
Zacccc
- Someone-Else
- Has thanked: 48 times
- Been thanked: 2604 times
Depends on the adaptor you use. Most should work.
- Zacccc (Sun Oct 09, 2022 10:30 pm)
- ericmark
- Has thanked: 118 times
- Been thanked: 785 times
As I said on the other forum "I am sure it is, but USB is max around 2 amp, at 5 volt, so 10 watt, this is so little heat, only likely to work as a hand warmer." I was looking at a 4 x USB plug 4 x 13A connector block, and noted the whole 4 were only rated 2 amp, where a wall socket with USB each is normally rated at 2.1 amp, so does depend on the adaptor as already said.
ericmark
Ok, thanks for that. I think then that I won't invest in one if they give so little heat.ericmark wrote: ↑Mon Oct 10, 2022 7:56 pm As I said on the other forum "I am sure it is, but USB is max around 2 amp, at 5 volt, so 10 watt, this is so little heat, only likely to work as a hand warmer." I was looking at a 4 x USB plug 4 x 13A connector block, and noted the whole 4 were only rated 2 amp, where a wall socket with USB each is normally rated at 2.1 amp, so does depend on the adaptor as already said.
Zacccc
- Been thanked: 219 times
But bear in mind just a blanket will help reduce your heating costsZacccc wrote: ↑Mon Oct 10, 2022 10:07 pmOk, thanks for that. I think then that I won't invest in one if they give so little heat.ericmark wrote: ↑Mon Oct 10, 2022 7:56 pm As I said on the other forum "I am sure it is, but USB is max around 2 amp, at 5 volt, so 10 watt, this is so little heat, only likely to work as a hand warmer." I was looking at a 4 x USB plug 4 x 13A connector block, and noted the whole 4 were only rated 2 amp, where a wall socket with USB each is normally rated at 2.1 amp, so does depend on the adaptor as already said.
Neelix
- wine~o
- Has thanked: 1415 times
- Been thanked: 4031 times
When I was a lad we would huddle around a candle when it was cold
When it got really cold we would light the candle...
wine~o
wine~o wrote: ↑Tue Oct 11, 2022 5:20 pm When I was a lad we would huddle around a candle when it was cold
You had a candle! ... Luxury!
My dad used to suck a mint and we'd sit round his tongue to get warm!
Zacccc
- Approved Electrician
- Has thanked: 225 times
- Been thanked: 664 times
I have worked on a few houses that were fire damaged due to candles and some involved deaths. I would never light a candle in my house.
OnlyMe
- Has thanked: 120 times
- Been thanked: 1043 times
If you are going to plug it into the mains get a proper heated blanket, they will put out much more heat. You can also get heat pads that you lie on, or even just get a cheap electric blanket designed for a bed, lay on that and put a normal blanket over the top of you.
My partner does WFH a lot now and the flat is a bit chilly in the winter. Rather than put the heating on I bought a heating pad which we put on her office chair, she then puts a blanket over her shoulder and legs. Keeps her toasty warm and only draws 10W on low which is often enough but if its really cold it can go up to 45W on high.
Rorschach
