10 wires, 4 holes...
Dan&sarah
Has thanked: 5 times
Post by Dan&sarah »
Have wired a few basic switches but come across a bit of a mix that I don't know where to begin. Have tried to get in contact with a couple.of electricians to do the job but all fully booked. I'm capable of following instructions (sometimes) so hoping someone can help
I have attached 2 pictures. One of the current 2 gang 2 way wiring
Current
Current
and the other of the socket I wish to fit. The black from.the 2 core and outside light blue are joined.
New
New
There is a 4 core wire to an outside light on left and 4 core to a 2 way landing light on right. I am unsure of the 2 core routing.
The switch I am fitting has L(A) L1, L2 and B.
Any help would be greatly appreciated
Daniel
Has thanked: 47 times
Been thanked: 2556 times
That is a 2 gang 2 way smart switch. It is not compatible with what you have. You would be better off installing a smart lamp.
Dan&sarah
Post by Dan&sarah »
Someone-Else wrote: Mon Dec 11, 2023 9:19 pm That is a 2 gang 2 way smart switch. It is not compatible with what you have. You would be better off installing a smart lamp.
Could you explain why in layman's terms? It may explain why I couldn't figure it out though. Haha. The switch is sold as a 2 gang 2 way switch.
And thank you
They do not "speak" the same language.
Bob225
Has thanked: 98 times
Been thanked: 872 times
Post by Bob225 »
to wire that type of switch you need to have a master switch and a slave switch, you can utilize the existing wiring
https://ilumos.com/pages/2-way-wiring
your current switch is 2 gang - 1 gang is 2 way and the other gang is 1 way
the switch you have purchased is 1 gang 2 way by the looks of it
Dan&sarah
Post by Dan&sarah »
Nope, it's definately the 2 gang 2 way I bought. I have the slave switch which is the same without the L2.
Dan&sarah
Post by Dan&sarah »
Bob225 wrote: Tue Dec 12, 2023 8:53 pm to wire that type of switch you need to have a master switch and a slave switch, you can utilize the existing wiring
<span class="skimlinks-unlinked">https://ilumos.com/pages/2-way-wiring</span>
I have seen that link but couldn't work out which wires to use fom the diagram
ericmark
Has thanked: 116 times
Been thanked: 782 times
Post by ericmark »
Two way wiring with standard switches can use two main methods to wire them, one needs a connector in the back box the other does not, so this
is the preferred method, but this
will work.
However with electronic switches the first method seems to be used, but the com wire does not carry 230 volt but a signal from the slave switch, so one has to follow the wiring diagram which comes with the electronic switch.
Also counting wires on original it seems you have two gang, and on new either it is only one gang, or it is using wireless connection to the slave, I was surprised not to see a wiring diagram on web site at first. but it did say:-
"Note: I LumoS 2 Way Switches can only work with another I LumoS 2 Way Switch and will not work with Mechanical Switches. I LumoS 2 Way Dimmer switch must be connected to another I LumoS 2 Way Dimmer Switch. A 2 Way Dimmer cannot work with a 2 Way On/Off by design. All I LumoS 2 Way Switches can also be used as an intermediate switch to create a 3 Way and 4 Way system. Please refer to the 2 Way and 3 Way Technical Support page for further assistance with wiring and operation."
On hunting further I did find the wiring diagram and it shows only 2 wires go switch to switch, not three as with mechanical switches.
Bob225
Post by Bob225 »
Do you have a pic of the front of the switch
your current switch
The 2 way circuit is (C) yellow, (L1) blue and (L2) Yellow
The 1 way circuit Is (C) 2x red, (L1) single Red
what wires do you have at the other switch as you have a twin and earth and 2 triple and earth cables
Dan&sarah
Post by Dan&sarah »
Thank you all for your help. I have an electrician lined up for in a couple of weeks if I can't figure it out. I don't like giving up though. Haha
Bob225 wrote: Sun Dec 17, 2023 6:13 pm Do you have a pic of the front of the switch
your current switch
The current switch is just a typical 2 switch.
The front of the I lumos is
The other switch is below. The right hand side is the same light
Bob225
Post by Bob225 »
It gets even more complex as you have another 2 way circuit
L is your common live, L1 and B is the 2 way
L2 is your 1 way circuit
Dan&sarah
Post by Dan&sarah »
Bob225 wrote: Mon Dec 18, 2023 7:42 pm It gets even more complex as you have another 2 way circuit
Thank you very much. Really appreciate it
Dan&sarah
Post by Dan&sarah »
All fitted and working well. For anyone having issues in the future these require a light fitting to actually be wired up. They seem to check for load via the electronics in the switch. Took us a while to figure that out.
These users thanked the author Dan&sarah for the post:
Bob225 (Wed Jan 17, 2024 9:38 am)
Bob225
Post by Bob225 »
The triac/mosfet needs a load to operate as it uses a common live between 3 way, no neutral also makes it more complex
Return to “Lighting”
