12V to mains
JohnBishop
Has thanked: 38 times
12V to mains
Post by JohnBishop »
big-all wrote: Thu May 02, 2024 9:13 am if you look at the saw is the writing on the blade mostly hidden??
Do you mean if the engraving on the old blade is worn off?
Has thanked: 740 times
Been thanked: 2355 times
12V to mains
Does the arrow on the blade rotate the same way when you run the saw(possible blade on back to front??)
JohnBishop (Thu May 02, 2024 1:44 pm)
OnlineOnline
JohnBishop
12V to mains
big-all wrote: Thu May 02, 2024 12:45 pm Does the arrow on the blade rotate the same way when you run the saw(possible blade on back to front??)
so the arrow on the blade correspond with the arrow on the plastic guard.
It cuts from below rather than from the top. Is that right?
12V to mains
the teeth must point forward in direction off rotation
OnlineOnline
JohnBishop
12V to mains
I check ed with the video and it rotates like in the video so luckily the blade wasn't the other way round.
Return to “Tool Talk”
