3 gang-2 way switch
seahawk72
3 gang-2 way switch
Post by seahawk72 »
all
Am replacing 3 gang 2 way light switch in hallway---both the outside switches are 2 way (one for hall and one for landing)-the middle switch is a one way for the outside lantern/light.
" attachments are the old switch and one is the new one
Unsure what the yellow wires are or where everything goes basically--am I right that the new one should be wired as COM and an L" for each of the 2 way lights with a COM and L1 for the outside 1 way switch, but which wires are which ?--and whats the significance of that small loop between A2 and the top middle terminal
I'm a bit stuck
thanks
Has thanked: 48 times
Been thanked: 2605 times
3 gang-2 way switch
No.
The middle switch you describe is correct.
Two way switching uses 3 wires/switch
The small loop is a live feed.
I suggest you invest in a very good marker pen and mark each wire (put a number on it or rings) Then take another clear in focus picture.*and check its in focus) So if it goes pete tong, you can put it back
I can't see what is in the last top terminal your picture is not that good.
Your new switch is like V V V
The bottom of the v is com, the top is L1 and L2
Your old switch is VMV (push the letters closer)
It is 3 2 way switches top to tail
and being as you know a 2 way switch on its own is V it should not take long for you to figure it out, but do take those pictures
Return to “Lighting”
