First thing to check is...... Does the temp ramp up if you just leave it in the bios at idle - if it does see below - if not it may be a windows issue with a process maxing out the cpu in the background
I see this on a regular basis the heatsink will be bunged up with fluff and fine dust you will not blow it out, open up the laptop (full strip down)
remove the heat pipe off the motherboard clean the old dry compound off with ipa, put on some fresh and make sure its the Non- conductive stuff
If its not fluff, it will be the fan - the fan may work at full speed but at lower speeds it will stall as the voltage/current is not enough to turn the fan
its a cheap fix and a few hours for a novice
Whats the make and full model number ?
laptop running hot (CPU?)
- wine~o
- Has thanked: 1415 times
- Been thanked: 4024 times
Re: laptop running hot (CPU?)
Full strip down and replacement of heat sink putty done. still running upper 50's until I followed this..
so seems to have been dried out compound and windholes running background crap.
Just one more thing... what do I do with the leftover screw????
Followed that and disabled some stuff. now happily running at under 50 degrees even under high load.boxedin wrote:Hello wine~o
Is it running windows 10? have you upgraded to windows 10 if so it might possibly be another potential cause to rule out before disassembling
https://fossbytes.com/windows-10-cpu-te ... ssue</span>/
- Mr. Grumpy
- Has thanked: 25 times
- Been thanked: 109 times
Post them to me, I seem to find lot more screw holes during reassemblywine~o wrote:Full strip down and replacement of heat sink putty done. still running upper 50's until I followed this..
- wine~o
Them ???? there's only one and it's 2.5mm thread x 2mm length... couldn't get the bugger in no matter hoe hard I tried.DIY_Johnny wrote:Post them to me, I seem to find lot more screw holes during reassemblywine~o wrote:Full strip down and replacement of heat sink putty done. still running upper 50's until I followed this..
