3 Gang 2 way wiring, please help
Al Sylvester
Post by Al Sylvester »
I'm trying to replace an old 3 gang 2 way switch. The old switch has wiring coded L1, L2 and L3 but the new replacement is only coded L1, L2 and COM. Having reviewed several ideas, I'm not convinced that wiring the L3 into the COM is the right option. I've attached photo's to help, but could someone please provide some clarification? Many thanks in advance.
New plug switch.jpg (248.53 KiB) Viewed 1637 times
Current wiring 2.jpg (83.13 KiB) Viewed 1637 times
current switch wiring.jpg (84.4 KiB) Viewed 1637 times
moderator2
UHM Super Moderator
Has thanked: 155 times
Been thanked: 569 times
Post by moderator2 »
:welcomeuhm: moved to lighting
wine~o
Has thanked: 1415 times
Been thanked: 4024 times
Post by wine~o »
Old switch New switch
L1 = Com
L2 = L1
L3 = L2
Probably a good idea to mark each core with marker pen or similar so that you don't get anything confunded.
wine~o
Post by wine~o »
In addition because you are fitting a metal switch you'll need to run a new earth wire from the back box terminal to the earth terminal on the switch
Al Sylvester
Verwood Handyman, sincere apologies for my lengthy delay, I must admit, I was very apprehensive rewiring the switch, as there was hardly a millimeter spare of any of the wires. However, I've successfully achieved it this morning, thanks to your amazing advice. Thank you so much, you are a star. I will definitely donate to UHM's charity, as you have undoubtedly saved me a wee fortune. Thank you again, and please keep up your incredible work and advice. Thumbs up, Al
Has thanked: 47 times
Been thanked: 2590 times
Al Sylvester
FYI his (forum) name is wine~O
Verwood is where he lives (Dorset)
His occupation is handyman.
No worries.
wine~o
Post by wine~o »
Someone-Else wrote: Fri Nov 27, 2020 10:04 am Al Sylvester
No worries.
I don't care what the OP calls me (within reason) Nice that They'll be making a donation to DDH
Return to “Lighting”
