Kitchen drawer front came off help need
taffer877
Post by taffer877 »
Hi my drawer door came off this morning and ideally I would like to reattach it but when I try it seems to be a struggle to get it back inside the clip (inside the cabinet door drawers).
The clip inside seems to be from FGV but I am not sure how it was originally installed and can't seem to find any precise name for it anywhere... all the videos on youtube seem to be about Blum...
Please can someone help me find a low cost solution to fix the problem?
Pictures attached,
c89bc858-f698-4cec-8a91-afcc5c7e2cf0 - resize.jpg (52.99 KiB) Viewed 3007 times
61cef725-5f83-4a40-a0ea-9fe8887cd01a resize.jpg (57.58 KiB) Viewed 3007 times
07faa189-5781-4411-a455-53b35d105351 resize.jpg (60.6 KiB) Viewed 3007 times
dae6bf6e-4104-4165-b105-dcfcb9e15d8a resize.jpg (55.69 KiB) Viewed 3007 times
623d4e47-9c4e-4729-b19e-7c327ef0ac3c resize.jpg (51.33 KiB) Viewed 3007 times
a45b5009-31bc-4c7d-97f2-9663c10a5f48 resize.jpg (50.94 KiB) Viewed 3007 times
Has thanked: 831 times
Been thanked: 3630 times
Is there a slot for a screwdriver somewhere? That looks like a cam action raises the locking bars that then grip the hooks on the drawer front.
OnlineOnline
The screw may be underneath in the runner channel. It will probably only turn a half but that will grab the hooks and lock the drawer front into place. Pull the drawer out a bit and have a good look all around the sides and open end.
OnlineOnline
darrenba
Has thanked: 104 times
Been thanked: 490 times
Post by darrenba »
You need to get the white bit out from the side of the drawer and clip it to the metal bracket on the front. Should pop out using a screwdriver in the 1st photo.
darrenba
Post by darrenba »
Return to “Kitchen Fitting”
