LPG Stoves
Stoves and stove related questions
kellys_eye
Has thanked: 357 times
Been thanked: 1790 times
LPG Stoves
Post by kellys_eye »
No, we're not traitors to the cause as we have a woodstove already but we also have a largish extension (sunroom) that sometimes needs heating in the winter. The woodstove heat is usually enough to keep the sunroom warm until it gets to minus-numbers outdoors when some supplementary heating would seem to be of benefit.
We're undecided as to flued or unflued but suspect, for simplicity, that the unflued version will win that argument but other than browsing a gazillion available versions I have yet to meet or discuss these devices with anyone that has PRACTICAL experience of them.
So.... anyone got one? Pro's and con's
Has thanked: 740 times
Been thanked: 2355 times
LPG Stoves
parafin lpg or gas all give out about a gallon off water per gallon burned :dunno:
Has thanked: 831 times
Been thanked: 3627 times
LPG Stoves
I would always go for an appliance that is room sealed drawing air in and venting waste products out to the outside air. A thing that sticks in my mind was back in the 60's when I was with the gas board. The natural gas conversion was well underway and part of the programme was ensuring enough air got into the room through vents. These were a bit self-defeating in heat loss terms with bloody drafts blowing through but the new gas needed more air to burn clean. We had a terrible case where a chap had unwittingly blocked all drafts in his bathroom to stop the cold. Unfortunately, he had one of those old fashioned water heaters over the bath, we used to call them geezers, and these appliances used a fair bit of fuel running a bath. Regrettably, his young daughter died in the bath as a result of monoxide poisoning. It was a terrible thing to happen and I have never forgotten her name, it sticks with me. So I may be biased towards the flued type of appliance.
I am sure you have thought of that issue already.
OnlineOnline
kellys_eye
LPG Stoves
Modern gas heaters (well, some) are fitted with catalytic converters that ensure 100% combustion and no CO - the ones I'm looking at also monitor oxygen levels and shut off if they drop 1.5%. Of course the mandatory 100cm^2 vent has to be properly fitted but that's just common sense.
As for condensation...... funnily enough that's not mentioned in all the bumpf and is usually an issue I know so maybe a flued one is better?
Has thanked: 48 times
Been thanked: 2604 times
LPG Stoves
big-all wrote: Thu Dec 24, 2020 2:11 pmparafin lpg or gas all give out about a gallon off water per gallon burned
Trying to understand how it can give off a gallon of water, if you only have a gallon of fuel in the first place? :scratch:
APDIY (Tue Jan 12, 2021 9:25 am)
wine~o
Has thanked: 1415 times
Been thanked: 4030 times
LPG Stoves
Post by wine~o »
Someone-Else wrote: Thu Dec 24, 2020 5:38 pm
https://www.bbc.co.uk/bitesize/guides/z ... revision/3 Chemistry dear Boy.
Razor
Has thanked: 483 times
Been thanked: 1251 times
LPG Stoves
Post by Razor »
Old tech but you can't go wrong with a Baxi Brasilia assuming you just need a couple of kW output.
Flueless fires are safe if installed exactly to regs but they are a decorative fire and the heat they give 1% of the year doesn't make up for the drafts the rest!
camallison
Has thanked: 127 times
Been thanked: 108 times
LPG Stoves
Post by camallison »
We have a balanced flue gas fire that exits outside, and draws in air that way too. It even has a remote control.
Best thing we did, buying it.
Colin
LPG Stoves
wine~o wrote: Thu Dec 24, 2020 5:48 pm Chemistry dear Boy.
It says you get water (I never questioned that) but what I don't understand is how you get 1 gallon of water if you only had 1 gallon of fuel
Return to “Stoves”
