Fitting door on bridging unit
yartin
Has thanked: 145 times
Been thanked: 129 times
Post by yartin »
Hi
I am trying to fit door into a pre assembled bridging unit. Pics below show the unit with pre drilled holes, door and the hinges/plates.
It should be straight forward BUT.
The 2 hinges goes into the pre drilled holes in the door is no issue.
However, do you agree there are no pre drilled holes for the hinge plates inside the unit? And they are drilled on the outside of the unit? Or how does it work?!
oz0707
Has thanked: 180 times
Been thanked: 69 times
Post by oz0707 »
Check the centres and pilot some holes in top. Job done. Did you get a strut?
yartin
Post by yartin »
oz0707 wrote: Fri Jun 25, 2021 6:41 pm Check the centres and pilot some holes in top. Job done. Did you get a strut?
Not sure which centres you mean? I got what's in the pic plus dumpers and braking arm- stay top flap
Can I drill through the outside holes already there? I measured and it's where the plates should sit from inside.
banjerbill
Has thanked: 7 times
Been thanked: 27 times
Post by banjerbill »
You've assembled the piece with the hinge holes upside down. Just take the unit apart and reverse that piece.
Bill
yartin
Post by yartin »
banjerbill wrote: Fri Jun 25, 2021 7:48 pm You've assembled the piece with the hinge holes upside down. Just take the unit apart and reverse that piece.
Bill
This is how it came, pre assembled. I thought of it but can't do that! How do you assemble it, see the pic below about the fittings if you see what I mean?
arco_iris
Has thanked: 184 times
Been thanked: 535 times
Post by arco_iris »
Edit reply
No they don't.
Turn cams 3/4 turn anti clockwise and knock sides off.
I thought that earlier but Yartin said "pre-assembled", so it may be glued. If turned over, the cams will be on the inside - be neater to drill through.
I agree with OP it's manufactured wrong though, send it back..... not much luck with kitchen suppliers, eh?
yartin
Post by yartin »
Bill
I tried, won't work, there are groves for the back board.
arco_iris
Post by arco_iris »
Oh yes, remember now, that's why I didn't post earlier.
yartin
Post by yartin »
arco_iris wrote: Fri Jun 25, 2021 8:22 pm Oh yes, remember now, that's why I didn't post earlier.
Yes it's either drill through which is fine or return, should be ok to drill, won't be seen.
Return to “Kitchen Fitting”
