Plastering block conservatory
mrmeanor
Post by mrmeanor »
Hello,
I have a conservatory built of concrete block up to about waist height, which is painted externally (possibly with a DPM but i cant be sure).
I'd like to plaster or plasterboard the inside to make it look nicer.
I see bostik DPM which can be used internally, and plasterboard dot and dabbed on top, then skimmed - https://www.bostik.com/ireland/en/catal ... erproofer/
Would this be sufficient to keep moisture from coming through to the plaster?
ahfix
Has thanked: 61 times
Been thanked: 184 times
Post by ahfix »
When was a built?
Is it single skin block? Is there a DPC layer under the block work?
Return to “Plastering Forum”
