Finishing skirting board.
Blakey
Has thanked: 247 times
Been thanked: 48 times
Post by Blakey »
Hi All,
I didn’t expect to be back posting so soon,
I have had new flooring fitted in my bathroom, and I am now fitting new skirting, my issue is how to finish the skirting at the architraves, the walls have been tiled down to the floor after the architraves were fitted, so the architraves protrude out approx 1/4 inch past the tiles, the skirting is approx 1/2 thick, the old skirting was planed/sanded down to a taper at the end to match the thickness of the architraves , not the greatest to look at, the skirting I am using is pencil edge if that helps, my question “is there a better way to finish the skirting boards up to the architraves?”
Thanks in advance for all/any advice given
You're never too old to learn something stupid.
ayjay
Has thanked: 458 times
Been thanked: 1708 times
Post by ayjay »
I can think of two options:- mark the edge of the architrave on the end of the skirting and create a pencil round (to the pencil mark) on the end - a block plane and some scratch will do this in a couple of minutes - alternatively,if you have a multi tool, cut off the bottom of the architrave and fit a plinth block with sufficient thickness to encompass the full thickness of the skirting.
Plinth Block
These users thanked the author ayjay for the post:
Blakey (Tue Aug 24, 2021 12:04 pm)
stevei
Has thanked: 94 times
Been thanked: 128 times
Post by stevei »
If your tiles are down to the floor why are you putting skirting board on?
Blakey
Post by Blakey »
Skirting boards were fitted before so there are lots of rawlplugs/holes visible in the tiles.
Grendel
Has thanked: 202 times
Been thanked: 526 times
Post by Grendel »
Just another idea , does it really need timber skirting in a bathroom ? Could not the skirting be tiles , either the same or contrasting colour. Alternatively how about thin plastic glued on to hide the holes ?
These users thanked the author Grendel for the post:
Blakey (Wed Aug 25, 2021 8:52 am)
