Can you please recommend a good joint compound and a filler?
adelast
Has thanked: 11 times
Post by adelast »
Hi everyone,
I am making my "item to purchase list" for my first project, can you please recommend a good joint compound for the plasterboards and a filler that I can use in bigger gaps between those?
Many thanks!
arco_iris
Has thanked: 184 times
Been thanked: 535 times
Post by arco_iris »
I use these (links):
Make Good Joint Compound & Filler should do both prior to plastering.
Toupret Expert Filler for filling after plastering.
These users thanked the author arco_iris for the post:
adelast (Wed Sep 15, 2021 5:31 pm)
adelast
Post by adelast »
arco_iris wrote: Wed Sep 15, 2021 5:16 pm I use these (links):
[url=<span class="skimlinks-unlinked">https://www.screwfix.com/p/make-good-mg ... 44gp</span>]Make Good Joint Compound & Filler[/url] should do both prior to plastering.
[url=<span class="skimlinks-unlinked">https://www.screwfix.com/p/toupret-toup ... 9358</span>]Toupret Expert Filler[/url] for filling after plastering.
Thank you @arco_iris!
Alistair86
Has thanked: 45 times
Been thanked: 4 times
Post by Alistair86 »
adelast wrote: Wed Sep 15, 2021 4:35 pm Hi everyone,
Many thanks!
Just my opinion after a job I have just done.
Firstly I want to make it clear I'm not a professional plasterer, just DIY.
I used the British Gypsum joint compound inbetween boards along with paper jointing tape.
I accept I may have done something wrong, but I would not recommend this method to anybody especially if the gaps are more than a couple of mm, but I would not use it regardless going forward, I found the mesh tape easier and gave a better finish.
The tape bubbled in certain areas.
However, as a filler, I would definitely use the jointing compound and nothing else going forward.
Just my opinion.
Return to “Plastering Forum”
