Wobbly slabs
_Chris_
Has thanked: 181 times
Been thanked: 2 times
Wobbly slabs
Post by _Chris_ »
I have inherited a patio where all the slabs have no grouting between them, just butted right next to each other. I've now come across a wobbly slab right in the middle, with about 8 slabs going in every direction from it.
How on earth do you get the slab up to rectify the wobble?
Has thanked: 48 times
Been thanked: 2604 times
Wobbly slabs
1) Suck it up. No, not joking, there is a suction machine that is often used to pick up heavy slabs. It needs two people to use it.
2) Walk it up. Put something thin down the gap and lift it up a bit at a time (You may need two thin things)
3) Move others around it away, starting from the edge
4) Hit it in the middle, then remove all the small pieces.
5) Get a set/pair of lifting tongs
Wobbly slabs
Found one
£90/first day hire from HSS
Has thanked: 740 times
Been thanked: 2355 times
Wobbly slabs
is there any gap at all ??
what size is it ??
_Chris_
Wobbly slabs
Post by _Chris_ »
Thanks so far.
The slabs are 60cm square, all around it are concreted down solid, with maybe a max of 1mm gap between them.
Wobbly slabs
ok you then look at a paint stripper with a wide flat blade then a perhaps 5 -10degree bend on perhaps the bottom 25mm/1inch then work it through then lean the handle back to push the "curve" under to the maximum and lift
other options wire coat hanger at the corner worked in
_Chris_ (Wed Feb 23, 2022 7:29 am)
_Chris_
Wobbly slabs
Post by _Chris_ »
Thank you, I think the paint stripper will bend and I don't think a 1mm gap will allow a coat hanger entry.
ahfix
Has thanked: 61 times
Been thanked: 184 times
Wobbly slabs
Post by ahfix »
Patio weed scrapper (L shaped tool) knocked down with a hammer?
These users thanked the author ahfix for the post:
_Chris_ (Thu Feb 24, 2022 10:01 pm)
Grendel
Has thanked: 201 times
Been thanked: 522 times
Wobbly slabs
Post by Grendel »
I've seen a couple of loops of wire , normally something like steel wire , slowly but successfully worked in the corners by rocking the slab .
These users thanked the author Grendel for the post:
_Chris_
Wobbly slabs
Post by _Chris_ »
Thanks to you both, some great ideas there.
ahfix - do you mean something like this:
https://www.amazon.co.uk/Draper-24935-C ... th=1&psc=1
ahfix
Wobbly slabs
Post by ahfix »
_Chris_ wrote: Thu Feb 24, 2022 10:03 pm Thanks to you both, some great ideas there.
<a href="https://www.amazon.co.uk/Draper-24935-C ... th=1&psc=1" class="skimlinks-unlinked" data-skimwords-word="https%3A%2F%2Fwww.amazon.co.uk%2FDraper-24935-Carbon-Weeder-Handle%2Fdp%2FB00AY05P4W%2Fref%3Dasc_df_B00AY05P4W%2F%3Ftag%3Dgoogshopuk-21%26linkCode%3Ddf0%26hvadid%3D224088607899%26hvpos%3D%26hvnetw%3Dg%26hvrand%3D11813675214676395905%26hvpone%3D%26hvptwo%3D%26hvqmt%3D%26hvdev%3Dc%26hvdvcmdl%3D%26hvlocint%3D%26hvlocphy%3D9045815%26hvtargid%3Dpla-422232291001%26psc%3D1%26th%3D1%26psc%3D1" data-skim-creative="500005" title="" style="">https://www.amazon.co.uk/Draper-24935-C ... 1&psc=1</a>
Yes - but you can usually pick them up at discount stores for £1.
ah
Return to “Gardeners World”
