How to prime filler before painting? Which product?
James500
Post by James500 »
I have a few hairline cracks which I have now filled. What primer can I use?
I have used poly cell product.
I have zinnser peal stop to hand. Can this be used on filler?
Or should I buy 123 bullseye? I am happy to buy another product.
I am a novice. I do not feel confident mixing emulsion and paint.
Tom d'Angler
Has thanked: 1142 times
Been thanked: 553 times
Post by Tom d'Angler »
You can prime the filler with some of the emulsion that you will be using to paint the ceiling / wall. Just water it down slightly first.
James500
Post by James500 »
Tom d'Angler wrote: Thu Mar 17, 2022 7:56 am You can prime the filler with some of the emulsion that you will be using to paint the ceiling / wall. Just water it down slightly first.
Thanks for the reply
How much water do I use?
So I can’t use 123 bullseye or peal stop?
James500
Post by James500 »
Sorry everyone. I mean I have never mixed emulsion and paint
Tom d'Angler
James500 wrote: Thu Mar 17, 2022 7:59 am How much water do I use?
Roughly 20% water to 80% emulsion. It doesn't have to be accurate.
James500 wrote: Thu Mar 17, 2022 7:59 am So I can’t use 123 bullseye or peal stop?
I wouldn't. I would use watered down emulsion.
James500
Post by James500 »
Tom d'Angler wrote: Thu Mar 17, 2022 8:08 am
Thank you I shall give it a try.
How would you measure the 20/80 split? I have a small measuring cup. Which can has measurements of 30ml, 60ml, 90ml and 120ml. On the other side it’s 1/4, 1/2 and 3/4.
It’s a small area so I wouldn’t need much. So if I used 60ml of emulsion do I add 12ml of water?
Desmondo15
Has thanked: 279 times
Been thanked: 327 times
Post by Desmondo15 »
Peel stop would be fine, Garda too. Not so keen on 123 on filler. Using a filler that doesn’t need priming such as toupret would help.
Watered down emulsion is the easiest.
These users thanked the author Desmondo15 for the post:
Tom d'Angler (Wed Mar 23, 2022 1:30 pm)
