Plaster dust - how to remove before painting
James500
Post by James500 »
Hi.
I have a bit of paint that pealed. The plaster is now exposed.
I plan to sand the area and apply peal stop.
However I noticed that when I touch the plaster my fingers are covered in plaster dust.
How to I get rid of this? Just use a Hoover then a ramp cloth?
I hope you can see the pictures.
Plaster
Plaster
Plaster
Plaster
ahfix
Has thanked: 61 times
Been thanked: 184 times
Post by ahfix »
I'd use a damp sponge. You also need to remove the peeling paint, I'm no decorator but the paint may not have adhered to the wall because it was over polished. A light sand and wipe down may help the pain stick.
wine~o
Has thanked: 1415 times
Been thanked: 4031 times
Post by wine~o »
Looks to me like the plaster was never "mist coated" which could easily cause that, mist coat BTW is a slightly diluted coat of emulsion (20% ish water to emulsion) applied before the topcoat/s.
This helps the topcoat/s adhere.
