Where could I get one of these cables?
Joe33
Has thanked: 6 times
Post by Joe33 »
Hello,
My LG widescreen display has a power cable a bit like a laptops. Jack in back of display, to box unit, and then a clover head plug to 10amp 3 pin plug. It's too short for me. I like to buy a 2-3m version of the last bit - clover head plug to 10amp 3 pin plug.
Can anyone send me a link where I can buy one of these online?
Thanks, photos below:
arco_iris
Has thanked: 184 times
Been thanked: 535 times
Post by arco_iris »
That type of connector is called an "IEC Type 5", search fleabay, A-zon, CPC, Ebuyer, Currys, loads of places.
These users thanked the author arco_iris for the post:
Joe33 (Thu Aug 18, 2022 3:15 pm)
Scotty001
Has thanked: 26 times
Been thanked: 174 times
Post by Scotty001 »
My usual go to is amazon, with next day delivery and many different lengths to choose from. Prices from £4 2m to £13 for 5m lengths.
I'd also drop the fuse rating down, (the transformer has a max of output of 3.42amp and input of 1.6amp
These users thanked the author Scotty001 for the post:
Joe33
Post by Joe33 »
So what amp fuse should I go with then? Can you put a 5amp fuse in a plug which says 13amp? Or must you buy a 5 amp plug for a 5 amp fuse and 13 amp plug for a 13amp fuse etc. ?
Thanks for the help.
Has thanked: 48 times
Been thanked: 2605 times
No, 13Amp on the plug means the highest rating fuse you can put in it.
So yes, you can put a smaller Amp size fuse in a 13A plug
Above is a picture of a 3,5 + 13A fuse, they are the same physical size so they will fit in a 13A plug. (one at a time obviously)
oh, you want a 3A fuse. (the red one)
Joe33
Post by Joe33 »
Thanks. Thought so just wanted to double-check. I'll order one and put a 3amp fuse in it. Thanks for your help.
Return to “Electric Forum UK”
