CH switching on and off Honeywell TR6-HW
neildel
Post by neildel »
Hi, did this issue get resolved in the end? I have exactly the same issue with my Honeywell TR6 and the 'boiler off' time means that the system never actually reaches the set point?
Any help appreciated.
Neil
moderator2
UHM Super Moderator
Has thanked: 155 times
Been thanked: 569 times
Post by moderator2 »
neildel, It's considered bad form to dig up old threads. I've started a new one for you.
Original thread here viewtopic.php?t=102461
Has thanked: 47 times
Been thanked: 2590 times
Not only bad form, but waste of time as in 99% of the time the OP that you ask a question of, no longer posts, so will never answer, in this case the OP made 7 posts in October 2020, 2 posts in Nov 2021 Never to be seen or heard of again. (All you need do is click on the name of the OP)
ericmark
Has thanked: 118 times
Been thanked: 783 times
Post by ericmark »
Can't remember model, but I know mothers thermostat had anti hysteresis software which as you approached the target temperature started a mark space ratio so it would not over shoot.
This would have been good with the oil fired boiler I have today, but not for a modulating gas boiler.
What happens if you turn up the temperature, in theroy the wall thermostat is just to stop the boiler cycling when all rooms are warm.
